Old 06-25-2008, 04:07 PM   #1
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Default Anyone have issues with Cosworth head gaskets?
I just got off the phone with Eric, an engineer at Cosworth. First I asked if their gaskets were made by Cometic. He says they are not and they are made by themselves. As far as the Cosworth head gaskets are concerned, they have never had a reported failure. After reading that some coatings on the steel gaskets can get scuffed off, I asked him specifically if this were to happen and he says that what people with supposed gasket failures don't take into consideration is that it is critical that the mating surfaces be absolutely be flat. He went on to say that don't trust anyone when it comes to double checking clearances and tolerances. If that was the case, he says car manufacturers such as Toyota, Honda, Nissan would not be using the nitrile rubber coatings on their oem gaskets. I asked if it that was used in the factory Subaru gaskets and he said not on the entire surface, just certain areas. He also said that the machine shops must have the proper tooling to achieve this. So I asked what kind of info I would need to double check with the machine shop. He says the RA (roughness average) needs to be 20 - 30 or better and to have them double check for mating surfaces flatness.
methaddict is offline   Reply With Quote
Old 06-25-2008, 05:22 PM   #2
modaddict
Member#: 95840
sold to a good bud
awaiting next car
yep, he is correct and this is old knowledge.
Most aftermarket shops CANNOT get the RA finish smooth enough. then you blow a head gasket.
modaddict is offline   Reply With Quote
Old 06-26-2008, 01:36 PM   #3
AVCSKIDD
Member#: 179372
We have never had a reported failure is a big red flag to me....thats total B.S.
You know someone has popped one.
AVCSKIDD is offline   Reply With Quote
Old 06-26-2008, 03:29 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
And if they haven't, they will. Stuff breaks, especially when pushed to the limit.
flycaster is offline   Reply With Quote
Old 06-28-2008, 07:59 AM   #5
bugeyes
Member#: 64494
2001 V7 sti
I bought a set of cometic head gaskets and later bought a set of Cosworths. Side by side the cutting profile is quite different.
The cosworths have the folded middle layer which gives a tighter seal around the bore of each cylinder which is the reason I bought them.
My last set of cometics leaked between the chamber and the water jacket. I wont blame the geaskets for that as I had an ecu problem which led to severe detonation.
Overall I have not been able to fault the Cosworth product (fingers crossed).
bugeyes is offline   Reply With Quote
Old 06-28-2008, 03:16 PM   #6
DoodieHead
Member#: 10236
2001 GC8 12.08@114
GT35R / Self Tuned 15lbs
I have a set of Cosworth Gaskets on my RS-t and have had no issues with them as of yet. They have been going strong for over a year now auto crossing and drag racing like crazy. I am impressed.
DoodieHead is offline   Reply With Quote
Old 06-28-2008, 03:30 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
RA needs to be very smooth and the lower the smoother. Old news indeed and is complete logical sense.
My surfaces get done at a 12 RA and haven't had an issue with cometics, yet (sorry, the engineer always leaves room ). Most also know that-that's pretty smooth.
Anyone have issues with their warranty with Carter's or Chaplin's? harryson North West Impreza Club Forum -- NWIC 11 04-20-2009 02:41 AM
Anyone having issues with NASIOC? Idaho General Community 9 08-01-2008 05:53 AM
Anyone have issues with bad welds on Stromung pieces? Siper2 Factory 2.0L Turbo Powertrain 6 08-12-2006 10:18 AM
Anyone having issues with XBOX live on the original XBOX? Anub1s Off-Topic 0 11-25-2005 05:11 PM
Anyone having issues with Cingular? 24 Mid Atlantic Impreza Club -- MAIC 13 06-16-2005 08:05 AM
Message Board Statistics All times are GMT -4. The time now is 10:25 AM.
