Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-25-2008, 05:23 PM   #1
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
Default Summer vs AS (Pzero M&S runflats?)
I need a set of tires for my Rota attacks... Currently I have nokian wr (yes AS/Snowflake) 235/45/17 that I use in the summer. I run Hankook Icebars in the winter on stock wheels.
So I'm interested in 225/45/17 sized tires that have a better speed rating than 80mph or whatever the nokian's offer. I don't drive much and when I do a lot of it is just highway and cruising around, therefore I'm not sure summer tires have anything to offer me. I drive aggressively on occasion but seeing as how the wr's have gotten me this far I don't think I need summers.
So the Tirerack is having a sale on PZero Nero M&S RFT (runflats) for $139 each, that's about as good as I've seen - they are Ultra Performance AS and the runflat aspect seems kinda cool ... BUT one of the reviews says they have very poor treadlife. This is another important factor for me - I want something that will last a decent amount of time, not 10k miles. That was one of two reviews so I'm not sure what to make of it.
Questions/Cliffs - Need Performance AS- Are the Pzero rft's good? Any real benefit for me in going with summers? - How much worst is treadlife? (Please don't say it's worth it to go summers because I have separate snows).
ptirmal is online now   Reply With Quote
Old 06-26-2008, 09:31 AM   #2
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
if running a runflat tire you MUST use a tire pressure monitoring system which will set you back a couple hundred dollars. The reason you must have the system is quite simple. A runflat tire is designed ot go a limited distance without air and because of the internal construction you can not tell the tire has lost it's air pressure jsut by looking so, it would be very easy not ot notice the zero air pressure condition and drive beyond the safe operation range of the tire. A monitoring system will alert you when the tire loses pressure to avoid the unsafe operation of the car
Old 06-26-2008, 10:19 AM   #3
ptirmal
Member#: 82243
07' Acura TL-S
Thanks Luke, what about the regular Pzer M&S? A couple of bucks more but still pretty cheap compartively... I'm trying to avoid spending 175 on the dunlops...
Old 06-26-2008, 12:40 PM   #4
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
take a serious look at the Eagle F1 A/S at only $131.00 they are best suted to meeet your desired results
use this link to find them
or check out the tests here
Old 06-26-2008, 12:48 PM   #5
ptirmal
Member#: 82243
07' Acura TL-S
Think I've decided on bridgestone re760 sport. My main concern was tread wear and wet traction. These are rated at 340 which seems sufficient and they're cheaper than some of the performance AS tires.
Old 06-26-2008, 01:44 PM   #6
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
if no snow traction is needed then that is a good choice but use this link to confirm the NASIOC connection
Old 07-09-2008, 05:28 PM   #7
tjsadler
Member#: 175126
If not driving through much snow you might also consider the General Exclaim UHP. I bought my 06 STi used and the dealer had put these on. Nice for daily driving through any weather. Not the performance you want for Autox or track but decent. i have driven 30000 miles and AutoX'd them 3 times and they are probably good for another 10000 miles. VERY cheap.
tjsadler is offline   Reply With Quote
Old 07-09-2008, 09:16 PM   #8
04funwagon
Member#: 163332
2004 WRX Wagon
I just bought the F1 A/S and am loving them, they handle great but as far as wear and tear I cannot help.
04funwagon is offline   Reply With Quote
FS/FT: Pirelli PZero M&S 225/45/17's bcristea Mid West Subaru Owners Club Forum -- MWSOC 12 10-01-2005 12:05 PM
FS/FT: Pirelli Pzero M&S 225/45/17 bcristea Private 'For Sale' Classifieds 11 09-30-2005 09:41 AM
05 STI BBS wheels + Pzero M&S nkkilla Mid West Subaru Owners Club Forum -- MWSOC 14 05-07-2005 12:31 PM
Toyo Proxes 4 vs. Pirelli PZero Nero M&S SUBE555 Tire & Wheel 69 10-11-2004 05:13 PM
BFGoodrich KDW-2 vs Pirelli PZero Nero's Deznuts05 Tire & Wheel 35 03-12-2004 01:45 AM
