Old 06-25-2008, 05:29 PM   #1
Evo killerz
Member#: 182874
2007 wrx
WR Blue
Default help needed ( gauges )
i have 4 gauges oil temp, oil press and boost, the oil temp and press gauge has 3 wires on each where do you connect them all up? and i also have an air/fuel ratio gauge with 3 wires on the back of it also where do they connect up?
thanks
Evo killerz is offline   Reply With Quote
Old 06-25-2008, 05:53 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you want an answer you're going to have to supply more information, like the brand and model # of the gauges. Also if you didn't get instructions with them (bought used?) you can usually go to the manufacturer's website for documentation. If the instructions are not posted there you can email their support people and they'll probably send you a copy.
Old 06-25-2008, 05:56 PM   #3
Evo killerz
Member#: 182874
2007 wrx
WR Blue
they are new but instructions dont give much help. they are autogauge gauges. and will i need some sort of sender for these to work?
Old 06-25-2008, 05:57 PM   #4
Evo killerz
Member#: 182874
2007 wrx
WR Blue
plus they all hav like 3 wires just on each each except for the boost it has 2 wires and the vacuum hose connection.
Old 06-25-2008, 06:36 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Assuming the oil pressure and temp gauges are electrical (sure hope they are), then yes you will need sensors for them. If you bought these new the sensors should have been included, so if they came from a vendor contact them and get the sensors.
The boost gauge sounds like it's mechanical so the two wires are for lighting. The hose goes to a manifold vacuum connection, preferably a tap from the hose on the factory bypass valve on the intercooler.
I don't see how the instructions are of no help, they should at least tell you what the wire connections/color codes are.
Old 06-26-2008, 06:02 AM   #6
Evo killerz
Member#: 182874
2007 wrx
WR Blue
what do these sensors look like?
Old 06-26-2008, 12:28 PM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
like this?
http://www.autogauge.com.tw/web/prod...tegorysubid=33
UkNuck is offline   Reply With Quote
HELP! Need Gauge Instructions Msquared Electrical & Lighting 1 12-13-2007 04:47 PM
Help....Gauge install help needed bigj514 Electrical & Lighting 0 12-21-2006 05:16 PM
Need some help on Gauges bigbear522 Canada Region Forum 6 08-25-2002 06:14 PM
need help reading gauges? Whitey Newbies & FAQs 5 04-02-2002 08:56 PM
WRX A/F Gauge help needed...if you have a wiring diagram stacarter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-26-2001 03:55 PM
