Notices
Old 06-25-2008, 10:40 PM   #1
scoobynewbie1
Member#: 150406
2006 wrx wgn
wrb
Default help with gauge install
i hope this is the right place to ask this question... i'm installing 3 prosport gauges in my 06 wrx tr tomorrow and i plan on using the clock wiring for all the power, illumination, and ground... with that many things gettin power from the clock, would that blow out any fuses or cause any electrical problems?? i've searched and couldn't find the answer... also would the readings be off that much if i tap my egt probe into the downpipe?? i've got an invidia catless downpipe and it already has an extra bung, so why not use it???
scoobynewbie1 is offline   Reply With Quote
Old 06-25-2008, 11:30 PM   #2
Jetta1120
Member#: 65676
2003 Subaru WRX
I used the wiring behind the radio for powering my 3 Prosport gauges in my '03 WRX and just ran an extra fuse between the connections and have not had any problem. As for the EGT Probe I dont really know, mine is ran to the headers i think, I had a buddy help me with installing the major hardware I just did the wiring.
Hope that helps a little
Jetta1120 is offline   Reply With Quote
Old 06-26-2008, 07:06 AM   #3
scoobynewbie1
Member#: 150406
2006 wrx wgn
wrb
thanks... i just don't wanna be poppin fuses or start a fire... i just don't trust myself as far as drilling and tapping the manifold... i guess i'll give it a shot in the the downpipe and see how it goes...
Old 06-26-2008, 07:21 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I'd suggest you stop before you go any further, and get some in-person help from someone with more experience. This isn't a very complicated installation, but there is still potential to do damage if you don't know what you're doing.
I can tell you this- the downpipe is not the place for an EGT probe, you won't get accurate readings there. The manifold is where it belongs.
Old 06-26-2008, 08:03 AM   #5
4thgenx42
Member#: 146312
I think he's more interested in just having move a little instead of it actually working. Search around in the forums there is a great write up on installing the EGT probe in the runners 3-4 in the exhaust manifold. Theres even a flat spot where it makes it perfect to drill the hole into and insert the probe. I did this to mine about 1 1/2 months ago and couldnt be any happier with the accurate readings... Search and ask your local forums for some help...
4thgenx42 is offline   Reply With Quote
Old 06-26-2008, 08:10 AM   #6
MIKE DD
Member#: 106818
2003 Truck
their is also a good wiring install on scooby mods, most people wire them to the running lights i believe.
MIKE DD is offline   Reply With Quote
Help with gauge install? WRXSteye20008 Mid Atlantic Impreza Club -- MAIC 5 05-12-2008 07:49 AM
help with gauge install SpectoRex South West Impreza Club Forum -- SWIC 21 09-28-2007 07:44 PM
Anyone wanna help with gauge install? AWD>FWD North West Impreza Club Forum -- NWIC 14 12-30-2006 09:51 PM
please help with gauge install.... anthony_delprete84 Electrical & Lighting 1 10-01-2005 07:25 PM
Anybody need help with gauge install Speedwagon Mid Atlantic Impreza Club -- MAIC 3 11-17-2003 07:44 AM
