Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 06-26-2008, 01:05 AM   #1
dahane
Member#: 165941
2008 LGT Spec B II
Silver Gray
Default Disable dinger for seatbelt????
I have a 2008 Legacy GT Spec B. Great car going stage 2 next week 300lb's of torque at the wheels here i come!!!
anyways I cant deal with the piezo speaker that goes off with the seat belts ON BOTH SEATS passenger and driver, as well as when starting the car..
I located the box under the steering wheel where the speaker is but i dont know if removing it is the best idea.. does this 20 lock and unlock work on 08's with the new passenger airbag monitoring system???
and if i did want to remove it or just clip the wire how would i go about removing the box to access the speaker??
HOOK UP SOME ANSWERS
dahane is offline   Reply With Quote
Old 06-26-2008, 11:11 AM   #2
Jutboy
Member#: 114371
in your seatbelt clip there are two wires that ether get connected or disconnect if a seat belt is clipped in.
Just find these wire before they go into the clip and short them or leave them permanantely disconnected.
Jutboy is offline   Reply With Quote
Old 06-26-2008, 05:18 PM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
Originally Posted by dahane View Post
...does this 20 lock and unlock work on 08's with the new passenger airbag monitoring system???...
umm... why not try it? and then if it doesnt work... you could let us know?... just a thought.
And I see no reason why disconnecting the speaker would be such a bad idea... you might lose your key in ignition reminder, but o well.
ProdriveDreams is offline   Reply With Quote
Old 10-25-2010, 03:48 PM   #4
RaineMan
Member#: 256727
2007 2.5I Wagon
I know this is a necro... but I just wanted to post in case anyone else was looking.
From this thread: http://forums.nasioc.com/forums/showthread.php?t=87540
RexyGirl's method works perfectly... just walked out to the parking lot and did it.
Originally Posted by RexyGirl
In order to disable (the seatbelt dinger) "permanent'y" (until the battery is disconnected), do this all within 30 seconds:
Open and close the drivers side door. Turn the key to the on position. Buckle and unbuckle the seatbelt 20 times within 30 seconds. Remove the key and open the door. Then, start the car. The seatbelt chime will go off 5 times (every time it is started) and then no more while driving.
HINTS: Never fully take the seatbelt out of the buckle. Release it and put it right back in. Also, make sure you count when the seat belt is released, not when you put it in.
Search = Win
RaineMan is offline   Reply With Quote
Disable dinger for seatbelt/door?? baziotes Electrical & Lighting 22 03-06-2008 03:19 PM
Policing for seatbelt usage perhaps? SlideWRX Mid West Subaru Owners Club Forum -- MWSOC 44 05-29-2005 10:59 AM
Disabled ABS for winter JVG Tri-State Area Forum 37 12-07-2003 12:24 PM
How about a new slogan for seatbelt use? rkkwan New England Impreza Club Forum -- NESIC 33 07-16-2002 12:17 PM
Disable AWD for FWD ak47th Transmission (AT/MT) & Driveline 7 05-27-2002 09:32 PM
