Welcome to the North American Subaru Impreza Owners Club Monday April 20, 2015
Old 06-26-2008, 03:06 AM   #1
misterwaterfallin
Member#: 101091
Default Nitto NT01 track pressure
Im a newb when it comes to track rubber. What level should I run these, and what should I start them out at at the beginning of the session to reach this level? Im headed to a track that will build a significant amount of heat. so the pressure should bump up quite a bit. its a 04 STI running track pads and just stage 2 if that matters
thanks for the help
misterwaterfallin is online now   Reply With Quote
Old 06-26-2008, 07:50 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
Are these brand new, full tread? What size? What sort of suspension? Alignment settings?
I'm running 255/40-17. I have found that mine like to be around 38 hot, when they were brand new I started around 27-28 front, 30 rear cold. Now that they've worn dwon a bit, they don't heat up quite as much so I start them at about 28.5 front, 31 rear.
This is with RCE T2's (500/400), Whiteline sways, KB endlinks, and Whiteline ball joint extenders. Aliment is set to -3 front, -1.5 rear with ~1/8 toe out in front, and 0 toe in rear.
mav1c is online now   Reply With Quote
Old 06-27-2008, 02:28 AM   #3
misterwaterfallin
Member#: 101091
im around the same with t2's 600/500, 24/24 whiteline sways, and an alignment with 2.8/1.5. they are near full tread, so I try 28 front 30 rear and see how it goes from there
Old 06-27-2008, 07:23 AM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Yeah. Sounds like a good starting point.
Old 06-28-2008, 12:38 AM   #5
ProjectL
Top Scoob 018
Member#: 66952
03 Wrx Wagowned
95 L swapped ver1 fmic'd
what about regular street tires on a track? my friend is running a set of kdw's with a similar set up to mine
ProjectL is offline   Reply With Quote
Old 06-28-2008, 02:50 PM   #6
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Hey how do you like the 600/500 rates on the T2's?
I have the 500/400 rates on mine, and I do a lot of autocross with some 17x10's. Therefore, I need a bit of ride height so i dont rub my fenders on my tires. (they poke )
I'm wondering if I get the stiffer springs, if I could lower the car a bit...
Acejam2k is offline   Reply With Quote
Tire Comparison: Nitto Invo vs. Nitto NT05 vs. Nitto NT01 PostRelease Interior & Exterior Modification 0 06-30-2009 01:30 PM
Tire Comparison: Nitto Invo vs. Nitto NT05 vs. Nitto NT01 PostRelease General Community 0 06-30-2009 01:30 PM
235/40/17 Nitto NT01 Track tires Nelly Wheels/Tires 22 11-17-2008 09:22 AM
FS: 235/40/17 Nitto NT01 Track Tires Nelly MWSOC Private Classifieds 3 11-12-2008 08:32 AM
4 Nitto NT01 245/45ZR17 track or race tires So. Cal. ocsubaru Wheels/Tires 5 03-14-2008 06:56 PM
