Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 06-26-2008, 11:54 AM   #1
-AspenSTi-
Member#: 164323
2005 STi
Default cel from turn signal replacement?
All i did was put the chrome bulbs in on the rear turn signals. And when i started my car the first time after that the starter made a wierd noise (the grinding sound) and my cel was on and the cruise control was blinking slowly. I havent had time to swap back yet (being at work and all) but the car drove fine and started back up without the starter problem after the first time (still with the cel and cruise control blink)... any ideas...
-AspenSTi- is offline   Reply With Quote
Old 06-26-2008, 06:20 PM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
definitely not the bulbs! CEL's only come on for a problem that one way or another will lead to higher emissions. Get the code pulled from a local autoparts store so we can help more from there.
ProdriveDreams is offline   Reply With Quote
Old 06-26-2008, 06:47 PM   #3
-AspenSTi-
Member#: 164323
2005 STi
I thought it seemed wierd, right after i put the new bulbs in. I will check the code when i get home just to know for sure. I was just cecking to see if anyone else had the same problem, I only thought it was the bulbs because the new ones were 7440A's and not the 7440's, just wanted to be sure...
Old 06-26-2008, 08:19 PM   #4
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
A stands for amber
Spore is offline   Reply With Quote
Old 06-27-2008, 10:04 AM   #5
-AspenSTi-
Member#: 164323
2005 STi
good to know, but i did find out that it was just a coincidence (how ever you spell it) that the bulb replacement caused the cel. The code was P0304, so its the dreaded cyl 4 misfire. Just thought i would let you guys know, thanks for all the previous help...
rattle from turn signal stalk SleeperWgn Interior & Exterior Modification 6 10-25-2010 12:29 AM
Rear Turn Signal Replacement seanr2 Baja Forum 8 12-11-2007 12:33 PM
Replacing Turn Signal Bulb ulei eagle Legacy Forum 3 02-21-2006 07:14 PM
94 to 99 steering colum replacement help! turn signals wipers ect wiring help scobaru Electrical & Lighting 0 03-10-2005 10:51 PM
is it possible to replace our turn signal flasher Basshead Electrical & Lighting 2 03-07-2003 02:22 AM
