Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 06-26-2008, 12:28 PM   #1
201Motorsports
Vendor
Vendor Sales Rating: (37)
Member#: 121809
2003 Evo VIII
Default Defi Red Racer and White Racer Gauges IN STOCK @ 201 Motorsports
Defi Red Racer and White Racer Gauges @ 201 Motorsports
No Control Unit Needed!!!
Exclusive gauges for the USA which are derived from quick-responsive and high-accurate Defi analog gauges.
* Stepping motor "STEP MASTER VS-2" provides smooth operation
* Ignition ON initiates self-luminescence gauge
* Red illumination using high-brightness LEDs
* Full 270 degrees sweep dial provides ultimate visibility
* A mounting bracket and instrument case is provided with the product
* The red triangle of the regular position bezel can be used as a warning indicator
* Does not require the Defi-Link Control Unit for use (Blue Racer Gauge cannot be connected to the Defi-Link System)
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
Sensor disconnection check:
This function reports any in-proper connections, broken or disconnected sensor or sensor wire. The pointer will wave between 250 and 260 degrees.
Short-circuiting check:
This function indicates any short circuit on the sensor or sensor wire.
__________________
[b]Phil
[COLOR="SeaGreen"]201 Motorsports[/COLOR]
[COLOR="SeaGreen"]Email[/COLOR]
phil[at]201motorsports.com
[center]
[/b][/center]
201Motorsports is offline
Old 07-03-2008, 09:39 AM   #2
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Bump!
__________________
[b]Phil
[center]
[/b][/center]
Closed Thread
