Old 06-26-2008, 05:51 PM   #1
denn
Member#: 169374
03 WRX
Default What are these wheels?
So I'm putting these on my car, but I have no idea what they are...
Anyone know? I need to get some center caps!
Thanks!
denn is offline   Reply With Quote
Old 06-26-2008, 06:13 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
No idea. Maybe some ADR's? Do you even know what size and offset they are?
Old 06-26-2008, 06:18 PM   #3
subaru3169
Member#: 55252
* pullup bar *
Originally Posted by mav1c View Post
No idea. Maybe some ADR's? Do even know what size and offset they are?
same what i was thinking lol
subaru3169 is offline   Reply With Quote
Old 06-26-2008, 06:40 PM   #4
flukewrx
Member#: 75081
2003 WRX
Where did you get the wheel from? You might want to check there.
However, as the others have stated, what is the size & offset of the wheels?
flukewrx is offline   Reply With Quote
Old 06-26-2008, 08:14 PM   #5
denn
Member#: 169374
03 WRX
17*7, not sure on the offset...
Got used, mystery wheels...they have the JLW scribe on them, beyond that nothing...
Old 06-26-2008, 08:23 PM   #6
subaru3169
Member#: 55252
* pullup bar *
are you sure there isn't anything else engraved on the back of the wheel?? check where the lug holes are.. there should be something..
Old 06-26-2008, 08:52 PM   #7
flukewrx
Member#: 75081
2003 WRX
Hmmm .... Are you sure they fit the 5 x 100 Bolt Pattern? If so, then there should be a stamp on the inside of the wheel (usually on a spoke) that shows the offset ( +35, +42, +53, etc. ).
Old 06-27-2008, 02:42 PM   #8
denn
Member#: 169374
03 WRX
Ah...I believe +40 (small circle against the lug backing.)
I'm going to have rubbing issues aren't I? (+19mm outwards compared to stock, am I right?)
Old 06-27-2008, 09:22 PM   #9
denn
Member#: 169374
03 WRX
Any one!??!
17*7's with +40 offset...odds of fitment under bugeye?
Old 06-27-2008, 10:29 PM   #10
Back Road Runner
Member#: 60082
2004 Forester STI
Well, +53 to +48 is more the normal range. +40 will stick it out a little ways, yes. Rubbing will depend on how wide a tire you run. Since it's only a 7" wide rim, you won't be going all that wide. If you're stuck to a 215 or 225 tire, you may not even rub. Even if it does, you might get away with just a little camber change or slight fender rolling and be good.
Old 06-28-2008, 12:44 AM   #11
denn
Member#: 169374
03 WRX
Cool, thanks for the input. Finished clearcoating them tonight, and im going to mock them up with some old tires tomorrow.
Do you know of hand what the wrx camber spec is?
Old 07-07-2008, 10:14 PM   #12
denn
Member#: 169374
03 WRX
I always hate finding a thread where a question is asked that matches the one I'm searching for, but never has an answer...
So, sorry for the delay, but 17*7's w/+40 with Falken Azenis RT615 235/40/17's fit nice under my 03.
Here's a quick pic. I'll get some more up someday when I can finally find the time to wash the beast.
Old 07-08-2008, 03:55 PM   #13
flukewrx
Member#: 75081
2003 WRX
Dude, the car looks good with those wheels. Surprised you went with the 235 tire size though, that seems like it would be too big for a 7 inch wide wheel.
Old 07-08-2008, 04:01 PM   #14
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
It's def a squeeze
Sideshowbob is offline   Reply With Quote
Old 07-08-2008, 05:18 PM   #15
denn
Member#: 169374
03 WRX
To be honest I went with 235's because I had 'em. They are pretty well used, but I wanted to see how the wheels looked on the car, before I spend money on fresh rubber. Mounting the 235's was pretty tough, I needed another set of hands and we were both prying to get 'em on.
But they have a nice flush look on the rim, that I'm pretty happy with, I'll try to get some closer up shots....
What are these wheels? sfwrex Tire & Wheel 7 01-24-2009 02:41 AM
what are these wheels?? [D.I.]WRX Tire & Wheel 2 02-18-2008 08:32 PM
what offset are these wheels...please look jimtweet Tire & Wheel 18 10-23-2006 07:47 PM
what are these wheels -please id them wrxdriven Brakes, Steering & Suspension 4 07-16-2001 02:53 PM
what are these wheels? antonRS WRX Forum Archive 7 02-19-2001 08:55 PM
