Old 06-26-2008, 09:19 PM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Who wants a video on swapping a front diff?
I am swapping a 4.44 front diff into a tranny for a rally car. Who wants a video how to?
I forgot to add this video will be SUPER handy if you crack a gear and have a donor tranny of ANY year (5mt that is). I will show how to swap out the gear sets. So all of you 02 WRX owners can possibly fix your trannies when you break them.
1st of course you need a donor tranny of course. I have purchased a few of them from salvage guys when the case is damaged.
As far as I can tell, all the 5mt gear sets can be swapped from case to case from 1990 to 2007, no crappola. But no guaranties either. But I have swapped quite a few gearsets from one year tranny to another.
There are two caveats though. 1st you will need the correct center diff if the gearset is newer, but you can use an older gearset in a new center diff. This is due to the way the 5th gear is setup.
The other is you need to use the correct pinion shaft. So you would not be able to just lift the gears out of a 4.11 and install them in a 3.9. You would need to swap the shaft. I cover this.
Old 06-26-2008, 10:08 PM   #2
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Who doesnt want a video how to. Post it up!!
I'll come in handy for when I destroy mine.
RonJitsu is offline   Reply With Quote
Old 06-27-2008, 02:31 AM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Doug, definately show us this. I will probably never do it, but if I knew I had a video to guide me through it, I just might....
~Josh~
Old 06-27-2008, 06:34 AM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
That would be nice, but I'm afraid you'd convince someone without the requisite skill to think they could mimic your actions into failure. Maybe I'm too cautious, but I've been told that a front diff is a pro only action by several tranny techs.
Old 06-27-2008, 07:47 AM   #5
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
I agree if you showed how to remove the rear diff then I have no problem but changing the front diff is no small job. However I would love to see a video just to learn. Getting that extra bit of knowledge never hurt anybody
talvai is offline   Reply With Quote
Old 06-27-2008, 01:32 PM   #6
frdawg
Member#: 24129
2002 wrx,EVO3 big16g
WRB 4.444fd Enginuity,E85
id like to see it,, i'm having the 4.444 conversion done at a shop, but it would be interesting to see how its done
frdawg is offline   Reply With Quote
Old 06-27-2008, 03:36 PM   #7
wrxjrk
Member#: 164093
Me Too.
wrxjrk is offline   Reply With Quote
Old 06-27-2008, 06:33 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If you don't have the correct tools then pleae don't bother. If you do have the correct tools then by all means please do.
Tim Sanderson is offline   Reply With Quote
Old 06-27-2008, 06:43 PM   #9
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
+1 for video. I'd love to see how this might be done.
axelthrasher is offline   Reply With Quote
Old 06-27-2008, 11:27 PM   #10
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Correct tools include
12 mm socket and wrench
14mm socket and wrench
27mm (1 1/16th") socket and impact gun
cold chisel and hammer
Really not that much needed.
And there is a trick up my sleeve to make it fairly painless... You use the donor shims that almost always come with the pinion shaft. So you do not have to worry about setting lash. I have done 7(?) trannies now and none have failed (except for that cursed one , had nothing to do with me )
Really, swapping out the front diff, or replacing the ring gear, is pretty damn easy. Exspecially compared to actually doing a gear repair. That is a whole nuther ball of wax.
The "chapters" will be...
1 - removing the center diff
2 - removing the bolts that hold the tranny case together
3 - opening the tranny case and viewing the innards.
4 - removing the 3 main parts, input shaft and gears, output (pinion) shaft and gears, removing the front diff.
5 - swapping the 4.11 pinion shaft for the 4.44 pinion shaft.
6 - showing how to replace the spider gear if needed
7 - reinstalling the 3 main parts
8 - putting case back together
9- reinstalling the center diff, which is often the most frustrating part of the whole ordeal.
10 - done.
Old 06-27-2008, 11:49 PM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Old 06-27-2008, 11:56 PM   #12
Mechie3
Member#: 120152
I'd like one. Maybe get someone to even take screen shots and make it a printable writeup, like your engine teardown writeup (when are you going to do an engine build writeup?!!??)
Mechie3 is offline   Reply With Quote
Old 06-28-2008, 03:34 AM   #13
ballitch
Member#: 74907
98 cam'd EJ251
Please dont forget the torque specs for the bolts you remove, it really helps to be able to search later on.......what am I talking about....this MIGHT get into the sticky section...
~Josh~
Old 06-29-2008, 11:33 PM   #14
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Half done with the swap....
I have torque #'s to give out, but cannot stand 100% behind them, but I will use them. They come from a factory service manual, but they say the 10mm and 12 mm bolts, but we all know they are 12 and 14! ?
Old 06-30-2008, 12:31 AM   #15
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
The manual is refering to the shank diameter not the head size.
Old 06-30-2008, 07:09 AM   #16
fastwrx25
Member#: 126441
03 bugeye
love to see the video.
I'm sure you would be helping out lots of ppl down the line.
maybe I can then install a obx front lsd myself if I ever grow some balls
fastwrx25 is offline   Reply With Quote
Old 07-10-2008, 03:04 PM   #17
blacktalon606
Member#: 73316
I want this vid as well!!! You never cease to amaze me man.
blacktalon606 is offline   Reply With Quote
Old 07-10-2008, 03:24 PM   #18
Back Road Runner
Member#: 60082
2004 Forester STI
I'm all for informational videos.
Old 07-10-2008, 04:22 PM   #19
mister_skinny
Member#: 117537
04 STI
WRB! & Silver 02 WRX
Default Front diff install
GIMMIE GIMMIE GIMMIE!!!
I need to swap out my STI Bell Housing, and this would help me out a lot!
mister_skinny is offline   Reply With Quote
Old 11-14-2008, 07:46 PM   #20
unclemat
Member#: 114530
2005 LGT 6MT wagon
So much for the video....
unclemat is offline   Reply With Quote
So who wants to save on STRI & DEFI Gauges? Save also on Innovate Widebands! Visconti Gauges & Electronics 71 07-26-2010 03:32 PM
can i swap the front diff without dropping the tranny? juice91si Transmission (AT/MT) & Driveline 3 10-22-2007 10:03 PM
Who wants a Version 5 swap in a GC? imdiaw Subaru Conversions 11 02-11-2005 04:51 PM
So Cal: Who Wants To Do A Swap?! movadovzo Private 'For Sale' Classifieds 2 02-07-2005 08:42 PM
Who wants a Rallycross on Snow ??? STiShawn Mid West Subaru Owners Club Forum -- MWSOC 30 12-15-2000 10:57 AM
