Old 06-27-2008, 12:34 AM   #1
jjs316
Member#: 135308
1997 Legacy GT
Default Gauges not working on 02 WRX
I am currently looking at a 2002 WRX here locally. I went to drive it today, and the speedometer, tach, and odometer do not work. The gas and temp gauge work just fine.
Would this be a wiring problem or would I have to replace the whole cluster?
jjs316 is offline   Reply With Quote
Old 06-27-2008, 02:47 AM   #2
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
short in wiring or a bad ground. and if it somehow is a bad cluster wrx ones arent hard to find and maybe you can get an 04+ with a center mounted tach
pearljam11 is offline   Reply With Quote
Old 06-27-2008, 06:14 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This is not a good sign on a car you are looking to buy. Without a working odometer there is no easy way to verify the true mileage. The problem could be real or "created" to hide something.
You can run a Carfax and check dealer records if available, but I'd suggest you keep looking and find a car where everything works.
Old 06-27-2008, 11:15 PM   #4
Clark Turner
Member#: 178047
02 WRX STI Spec C
Does the car have accessorys wired in like gauges? If so they might have over loaded the interior or clock fuse. Pull all the fuses and check them.
Clark
Clark Turner is offline   Reply With Quote
Old 06-28-2008, 11:46 AM   #5
jjs316
Member#: 135308
1997 Legacy GT
Clark
It has the 3 gauges that are where the clock was. Well the boost one is missing but the other two are there. The A piller trim is missing, so there could have possibly been gauges there at one point in time. I check the fuses on it.
Thanks for all the replies!
Old 06-29-2008, 03:45 AM   #6
pearljam11
Member#: 113335
13 WRB BRZ Limited
This car was modded and probably driven harshly this plus the electrical problems find another car.
Old 06-30-2008, 05:02 PM   #7
Clark Turner
Member#: 178047
02 WRX STI Spec C
Check all the fuses with a continuity tester. THen swap the relays around. You will find two fuse boxes. One under the hood and one under the dash on the left side. Most of the relays are the same so you can swap them around as a test.
Clark
A/C is not working on '04 WRX mattswrxnc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-28-2012 10:49 AM
Rear sti hubs work on 02 wrx? easiest way to get rear brembos to work... skate enjoi Brakes, Steering & Suspension 19 07-21-2008 04:25 PM
things that are NOT working on my WRX mchrenen Electrical & Lighting 4 07-16-2008 12:31 AM
need stock ECU preferably not working!! ASAP 02 wrx aftermathWRX Private 'Wanted' Classifieds 3 02-06-2005 01:22 PM
Will 02 TS wagon top hats work on 02 WRX wagon struts? poison Brakes, Steering & Suspension 2 01-14-2004 12:28 AM
