Old 06-27-2008, 12:36 AM   #1
hatrick32000
Member#: 161729
2006 wrx sti
CGM
Default hooking up a boost and vacuum gauge?
i dont know if this is the right section but i have a boost gauge already and want to buy a vacuum gauge as well but do i have to run the hose from two different places or can i run the vaccum T fitting and its hose right from the boost hose i have that is connected to the bov.
hatrick32000 is offline   Reply With Quote
Old 06-27-2008, 05:27 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A boost gauge IS a vacuum gauge. Basically it is a manifold pressure gauge, it reads the pressure in the manifold relative to atmosphere from negative (vacuum) to positive (boost).
Old 06-27-2008, 08:56 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
not always... there are lots of boost gauges that start at atmospheric pressure and go up, they have no vacuum scale. I know of at least 2 different vehicles that came equipped with this type of gauge OEM. (and of course, lots of vacuum only gauges that end at 0)
http://www.boostcontroller.com/index.php?item=106
to the OP... if you have a boost gauge that doesn't read vacuum, find a new gauge to greatly simplify your life. If you REALLY want two gauges, yes you can just tee off the line going to your other gauge.
Old 06-27-2008, 10:58 AM   #4
hatrick32000
Member#: 161729
2006 wrx sti
CGM
ok thanks yea my boost gauge doesnt have vaccum and i just need one more gauge to fill my cluster and vaccum is easy. so yea ill just tee it off my boost line then. thanks
Old 06-27-2008, 11:31 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
one thing to consider is that the vacuum only gauge may have a diaphragm that could rupture when hit with ~16 psi of pressure. just speculation though, you won't know until you try it.
Old 06-27-2008, 01:26 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yep, you could damage the vacuum gauge with positive pressure. I suppose you could put a relief valve in the line for it, and a check valve to prevent the relief valve from causing a vacuum leak, but why go to all that trouble when you can just replace your existing boost gauge with a full-range one and get something more useful for that extra spot?
2002 Stock boost and vacuum gauges not working Hagwag02 Interior & Exterior Modification 7 06-06-2009 08:13 PM
how to hook up 2 boost gauges WRXINXS Interior & Exterior Modification 12 03-17-2006 07:32 PM
Selling OEM boost and vacuum gauges txl146 Private 'For Sale' Classifieds 8 10-09-2005 09:45 PM
hooking up a boost gauge... killawrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-31-2004 11:48 PM
How are people hooking up mechanical boost gauges? QA Guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-19-2002 06:26 PM
