Old 06-27-2008, 12:56 AM   #1
password:ej20
Member#: 178729
1999 ver6 sti
rally blue
Default 5x100 to 5x114 conversion in order to fit bbs on bug-eye
well just wondering, i got some mint sti silver bbs wheels and looking to snap them on the bug-eye
quick questions before i do it up
1)the adapters im getting are about an inch wide to convert the 5x100, how wide will these look with the bbs 17x8 on there
2)anyone got pics of a bug eye with staggered fit bbs wheels (as in the 17x8 plus the 1 inch from the adapter??
3)will it rub fenders if im dropped on tanabe nf210s??
password:ej20 is offline   Reply With Quote
Old 06-27-2008, 01:01 AM   #2
Arctic Penguin
Member#: 119532
2006 WRX
not gonna work
too wide
too low
Arctic Penguin is offline   Reply With Quote
Old 06-27-2008, 09:59 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
1. that spacer is going to change the offset on those wheels from +53 to +28. not even the 'hella flush' guys on nasioc go that low with offset.
2. how is it going to be staggered if you're going to be using the 25mm spacer on all 4 corners?
3. definitely. with a drop and that low of an offset, you'll definitely need to roll the rear fenders, probably need to pull them out, and get some rear camber bolts.
Old 06-27-2008, 12:32 PM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Hmmm...I like these shoes, and it's such a good deal, but they're too small. Bah! I'll just cut off my toes!
Old 06-27-2008, 11:29 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
to the op, why not just get 04 sti bbs wheels?
They will fit, but your going to need some camber bolts in the rear. There are many guys running that low of an actual offset, Im running 18x9.5 +40 with a 10mm front spacer. There are others running +22-+29 also. Theres a thread in the members gallery that is stickied just for this.
scby rex is offline   Reply With Quote
Old 06-28-2008, 06:51 PM   #6
armigerlives
Member#: 180958
2008 Homemade
Yellow
lmao If your fenders are causing you to stumble, throw them away from you!
armigerlives is offline   Reply With Quote
Old 06-28-2008, 07:59 PM   #7
Foxy
Member#: 33069
2008 STI
Do it right and do the conversion kit. 6Gun racing sells it. But if you're going to all that trouble, why not get wheels wider than 8"?
http://www.6gunracing.com/products.asp
Or, just get some 04 STi wheels.
Foxy is offline   Reply With Quote
Old 06-29-2008, 01:51 AM   #8
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
i dont know why ppl r so scared of low offsets. 17x8 +28 is equivalent to 17x9 +40, or 17x8.5 +34 as far as how it sits against the fender, which isnt that hard to fit at all. BUT, if u want less hassle Project Kics makes a 15mm lug conversion spacer that u might want to look into.
ommmjido is offline   Reply With Quote
Old 06-29-2008, 02:06 AM   #9
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
but why? He could just get 04 sti wheels or some other 5x100 wheels that he wouldn't need a bolt on spacer for. I see what your saying about the sizing not being that aggressive as far as outer clearance, but it just doesn't make enough sense to run that kind of sizing.
blahhblahh is offline   Reply With Quote
Old 06-29-2008, 02:32 AM   #10
ommmjido
Member#: 35746
08 White GRB
thats the problem with ppl on Nasioc, always questioning ppl's questions rather than answering them. Why would he do that? i dont know and i dont care, all i see is a question and i'll try my best to answer. is that an ideal size? No. would i do the same? No. to me it doesnt make enough sense to run 17x7.5 but i dont go and ask everyone why they didnt get 17x9 instead of a 17x7.5.
Old 06-29-2008, 09:36 AM   #11
mav1c
Hoodbridge!
Member#: 560
Actually I wasn't questioning the OP, just giving a sarcastic response implying he shouldn't do what he's thinking of doing.
Old 06-29-2008, 04:51 PM   #12
Web Foot STi
Member#: 39086
2004 STi
Wheel bearings are a PIA to change. Small offsets don't help. We question for a reason...
Web Foot STi is offline   Reply With Quote
Old 06-29-2008, 06:52 PM   #13
StockDiesel
Member#: 134901
2008 WRX STI
Lightning Red
yeah, you are going to burn up your wheel bearings, suby front's are a notorious weak spot, trade the 114's for 100's, less headaches
StockDiesel is offline   Reply With Quote
Old 06-29-2008, 06:54 PM   #14
Daishi00
Member#: 78952
2005 WRX
CGM
Because there is a front and back side to the wheel, so pushing out the front and not having a corresponding increase on the back (like with a 17x9") is what helps kill the bearing....front loading the wheel.
Daishi00 is offline   Reply With Quote
Old 06-29-2008, 07:37 PM   #15
ringe
Member#: 49998
2007 WRX CT Stg 2
+1000
ringe is offline   Reply With Quote
Old 06-29-2008, 09:24 PM   #16
Rancid
Member#: 3272
2016 VW Golf R
He has a point to prove!
http://forums.nasioc.com/forums/show....php?t=1539248
Rancid is offline   Reply With Quote
Old 06-30-2008, 12:00 AM   #17
Kylar
Member#: 159215
2008 LGT Limited
lol, whats going on in here? password:ej20 how old are you?
Like everyone said your best and probably cheapest bet would be to sell the rims on ebay and buy a 5x100 set.....but your probably not going to do that for at least a month or two, because you wont admit you are wrong and should have done more reseach before buying the 5x114.3
Kylar is offline   Reply With Quote
Old 06-30-2008, 12:10 AM   #18
Arctic Penguin
Member#: 119532
2006 WRX
he's one of these kids that knows it all and is gonna prove it
bet he wont post the massive failboat thread when he realizes how bad it is gonna be
Old 06-30-2008, 03:12 PM   #19
remowgn
Member#: 41149
09 FXT
SSM
That's the difference between wanting to answer a question, and wanting to help somebody. If somebody asked how to disable their wastegate so they could run 30psi of boost on pump gas, would you tell them without letting them know they're gonna blow up their car?
More information is never a bad thing. If he wants, he got all the info he actually needs from the responses here, plus more. Personally, I wouldn't do it, because the price of the wheels (unless they were ridiculously cheap) plus the spacers is bound to be the same or more than getting a set of 04 sti wheels.
remowgn is offline   Reply With Quote
Old 06-30-2008, 09:48 PM   #20
scby rex
Member#: 104878
02 wrxbastardchild
Originally Posted by Rancid View Post
hahahahah rancid your everywhere! hahah "tightass pants!"
Old 07-01-2008, 12:15 AM   #21
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
I dont think he ever bought the rims. I tried to help/warn the kid, but 18 year old ex-"JDM swapped Integra" kids just dont get it...
http://forums.nasioc.com/forums/show....php?t=1506114
http://forums.nasioc.com/forums/show....php?t=1510403
lackofhp is offline   Reply With Quote
Old 07-01-2008, 01:03 AM   #22
Arctic Penguin
Member#: 119532
2006 WRX
yeah
ive had some kiddys that thought they had their wrxs all hooked up mad tyte get all boned up with me when i told them what they had done wrong with their car go for a ride in mine at a meet and at the next meet
their cars had been quietly re-modded
go figure
Is this offset going to fit my 03 bug-eye? WRBlueberry Tire & Wheel 2 03-24-2010 09:06 PM
5x100 to 5x114 conversion help 06WhiteWRX Tire & Wheel 14 02-06-2007 10:34 AM
STi BBS on Bug Eye. BlueBomber Tire & Wheel 6 07-15-2006 10:37 PM
STi BBS on Bug Eye. BlueBomber Mid Atlantic Impreza Club -- MAIC 19 07-14-2006 02:12 PM
What would have to be done in order to run 28lbs of boost?? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-30-2003 03:35 PM
