Old 06-27-2008, 12:22 PM   #1
manxaru
Member#: 123021
Default 2.5 Sti block question...
manxaru is offline   Reply With Quote
Old 06-27-2008, 12:33 PM   #2
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I do believe both are oil and both are normally plugged from the factory. The rear one is where people typically add an oil pressure sensor by way of a replacement plug and remote mount kit.
Scooby921 is offline   Reply With Quote
Old 06-27-2008, 03:53 PM   #3
manxaru
Member#: 123021
Thanks for the reply.
Any second opinions on the boss closer to the crank end? When I look into the hole with the plug removed it looks kind of wide open and deep to be an oil galley, but I need to be sure...
Old 06-27-2008, 04:32 PM   #4
badblackwrx
Member#: 102565
2002 MBP JDM V7 6SPD
2.5 HYBRID + BREMBOS
The one towards the back of the engine is where the oil line attaches to your turbo. The one in the front is where the oil pressure sensor is located.
badblackwrx is offline   Reply With Quote
Old 06-27-2008, 05:37 PM   #5
charliew
Member#: 125304
1/2 right 1/2 wrong
The one in the front is where the stock oil sender goes, it's over the gallery that goes to the oil pump, filter and mains.
The one in the rear is over the rear main. They are connected together. The one in the rear could be used for a non-stock oil sender.
The turbo oil feed for both the wrx and sti is on the rear of the passenger head. The port in the head for the turbo has a restricter in it to reduce the volume of oil supplied to the turbo.
charliew is offline   Reply With Quote
Old 06-27-2008, 06:53 PM   #6
novacivic
Member#: 117980
2005 sti
wr blue
Originally Posted by charliew View Post
1/2 right 1/2 wrong
100% correct
novacivic is offline   Reply With Quote
Old 06-27-2008, 09:41 PM   #7
manxaru
Member#: 123021
Thanks guys.
Is it safe to say that since the two ports are connected together that you would see the same oil pressure at either location?
2.5 STI block v 2.5 na blacktalon606 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 04-20-2006 11:54 AM
2.5 sti block questions WRXnut02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-17-2004 11:59 AM
Yet another 2.0 to 2.5 sti block ? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 12-22-2003 03:24 PM
Yet another 2.5 sti block question.... serious Subaru Conversions 9 10-13-2003 09:35 PM
2.5 sti block with 2.0 regular wrx heads serious Normally Aspirated with bolt-on Forced Induction Powertrain 21 08-03-2003 12:36 PM
