Old 06-27-2008, 03:30 PM   #1
subajay
Member#: 89688
1996 audi a4
white pearl
Default Valve job
Well recently my timing belt skipped a tooth and valves were bent. I am as of now sourcing options. I could replace heads all together and upgrade but money is my heartbreaker. I could buy new valves and replace my old ones. (here is my question for you all).
My setup is as follows
axis stage 2 block
stock 02 wrx heads
fp 18g (plan on going either fp green, red or a frank 30)
ported exhuast mani, intake mani throttle body and tgv delete
modded stock wrx injectors
and all other bolt ons
So for what i am looking for and if i cannot come up for the money for better heads (sti heads) what would you say to get for valves
oem
supertech
AND now i thought you had to port the intake and exhuast ports to run "oversized valves" but i believe i read an article (unless confused on what they wrote) the i could run .5 oversized and another person stating a full .1 oversized on stock ports.
Thanks for the help in advanced.
subajay is offline   Reply With Quote
Old 06-27-2008, 05:50 PM   #2
charliew
Member#: 125304
You will need a sti wiring harness and ecu to use sti heads to their full potential. Why go to bigger valves without opening up the ports to take advantage of the larger valves?
Going to sti cams and new stock valves will probably be cheaper than buying bigger valves and cutting the seats out for larger valves.
Unless I saw a flow bench printout of just using bigger valves that shows a improvement, I don't think the stock size ports will support bigger valves.
charliew is offline   Reply With Quote
Old 06-27-2008, 10:20 PM   #3
subajay
Member#: 89688
1996 audi a4
white pearl
alright that's all i really needed Now since i believe i only bent two valves would i be fine replacing just those to? heads have around 60k on them maybe little less.
Old 06-28-2008, 02:15 AM   #4
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
yup....you could do just that. you could.
but if you're going to go with a bigger turbo, your WRX heads will definitely be the biggest restriction in making big power with a FP Red or bigger.
you don't need STI heads...just find someone to do a ~stage 2 port (or there's a DIY head port thread in here), milled for +1mm valves, and a multi-angle valve job, and you're good to go.
Look at getting SS intake valves and inconel exhaust valves for some extra safety, but not necessary.
I recently found these guys, that have Supertech valves for a really good dealio:
http://www.importperformanceparts.ne...es-subaru.html
I realize your short on cash, but given your future mods.....do this now and do it right.
my .02
EDIT....but honestly, talk to your tuner about it and get recommendations from him.
UP2MTNS is offline   Reply With Quote
Old 06-28-2008, 11:51 AM   #5
subajay
Member#: 89688
1996 audi a4
white pearl
tuner told me for now just to do stock valve replacement and get sti camshafts (picked some up for 200 =-0 =-]) I'll buy an extra set of wrx heads and do them up.
Thanks for the info guys!
Old 06-28-2008, 12:00 PM   #6
subajay
Member#: 89688
1996 audi a4
white pearl
next question.... from that site i see one std-standard size but now is that intake and exhaust i always thought exhaust was a teed bit bigger.
Old 07-03-2008, 11:29 AM   #7
captureandrelease
Member#: 176014
2003 wrx wagon
Rally blue.
Subajay, where is my intercooler I paid you for 6 weeks ago?
captureandrelease is offline   Reply With Quote
Old 07-03-2008, 02:41 PM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Oh SNAP!!!!!
Old 07-04-2008, 04:22 PM   #9
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Std just means standard (OEM) diameter of the valve. The valves are different sizes intake vs. exhaust. Ordering standard size valves, both sides, will get you standard size intake and standard size exhaust.
/Brox
Broxma is offline   Reply With Quote
Old 07-05-2008, 02:03 PM   #10
Weemus
Member#: 16415
02 WRX+1.5XTR+E85=
WRBwhatothercoloristhere?
Got a question. Don't mean to hyjack but I'm doing the exact same senario and I am doing a home port and polish. I am going to have a local machine sop do a valve job but I would mind going with slightly bigger vavles. Do I need to have the seat replaced or will it support +1mm valves?
Weemus is offline   Reply With Quote
Old 07-17-2008, 08:45 PM   #11
captureandrelease
Member#: 176014
2003 wrx wagon
Rally blue.
Subajay, where is my intercooler I paid you for over 2 months ago? Buyer beware!
Old 07-19-2008, 03:33 AM   #12
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Hi sorry to jack the thread as well.
Very soon im doing a sti 2.5 hybrid swap. Im rebuilding my 2005 wrx heads using supertech valve, springs, retainers, ect. "stock cams for now" evo 316g or 18g Just for now i dont want to spend a lot on a bigger turbo "green, gt30, ect." Until i can save up to buy a 6spd or build my 5spd in 6ish months. once i buy a tranny upgrade ill go green or rotated.
So im having my heads rebuilt as stated above. standard process pressure test, clean redeck them, 3 agle valve job. ect. My friend is nice and wont charge me any more to port my valves 0.5-1mm now.
Should i go ahead and go with bigger valves now? I dont think he is planning on pnp the whole intake and exhaust ports much. More just a bulletproof rebuild plus a lil extra. Or is it overkill and will hurt the performance if a small turbo like a evo3 16g?
Sorry again for stealing the thread.
Thanks for any input.
rexworx is offline   Reply With Quote
Old 07-19-2008, 03:53 AM   #13
kellygnsd
Member#: 32669
LINK G4 hybrid STi
If you plan on doing in later, do it now unless you like wasting time and money pulling the motor and breaking it down so you can do something you could have done in the first place. If you have the funds to do heads, cams, valve, the whole shabang-a-bang do it now or pay double later.
Search my threads, I talk about my experience with heads/cams + small turbo.
Old 07-19-2008, 11:59 AM   #14
rexworx
Member#: 103232
^^^ Thanks!
shift kits? valve job? t3hWIT Transmission (AT/MT) & Driveline 4 02-24-2005 06:38 PM
Who do you use locally for head work/valve jobs (NNJ)? Charlie-III Tri-State Area Forum 4 01-01-2005 09:12 AM
bow to GFB Blow off valve job? kenchan Mid West Subaru Owners Club Forum -- MWSOC 7 05-30-2003 05:03 PM
Need local company for valve job and cleaning WRXwannbe Bay Area Impreza Club Forum -- BAIC 0 10-05-2001 12:03 AM
GRM's Head Game Atricle - Anyone considering a valve job cOz Technical Forum Archive 9 06-26-2000 04:19 PM
