Old 06-27-2008, 07:01 PM   #1
WhiteH2O
Member#: 452
'06 GX470
Default Compressor stall, or ?
For some reason this has been happening more after I got the 6 speed put in. When I shift down, like 6th to 4th, or 5th to 3rd, and get on it, the car feels like it is shuddering quite a bit and it takes a little while to gain power back and stop shuddering. I have been playing with it a little bit, and it seems that if I rev the engine above where the rpms will be after the shift, this helps it from happening a little bit, but it doesn't stop it completely.
So, does this sound like compressor stall, and how about might I go about fixing it? This is a 2.5l hybrid with wrx heads, 20g turbo and a TXS bypass valve.
WhiteH2O is offline   Reply With Quote
Old 06-27-2008, 07:23 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
why do you skip gears?
Old 06-27-2008, 07:35 PM   #3
WhiteH2O
Member#: 452
'06 GX470
I don't always, but if I am driving in 6th and some semi tries to run me over or something, shifting into 5th doesn't really get me into my powerband. Or, when I slow down for a turn in 5th and accel out of it in 3rd.
Either way, it still has happened while just downshifting one gear also, but not as often.
Am I the only one who downshifts more than one gear at a time?
Old 06-27-2008, 07:38 PM   #4
n2oiroc
Member#: 141952
15 legacy 16 wrx
nope, i skip gears a lot too. its harder on the syncros, but oh well.
n2oiroc is offline   Reply With Quote
Old 06-27-2008, 07:40 PM   #5
WhiteH2O
Member#: 452
'06 GX470
It shouldn't be if you rev-match and double clutch.
Old 06-27-2008, 08:03 PM   #6
n2oiroc
Member#: 141952
15 legacy 16 wrx
im too lazy for that.
are you sure your problem isnt tune related?
Old 06-27-2008, 08:24 PM   #7
WhiteH2O
Member#: 452
'06 GX470
No, that is sort of what I was hoping to get a feeling of from people here.
This is the same tune that I had before the 6 speed swap, and it was rare for that to happen with the PPGs. Unless the gearing changes changed the load on the engine, I don't think it is tune related.
If it is tune related, maybe I can use that as an excuse to get new cams. I would hate to have to get a new tune for no reason, cams and TGV deletes sound like a good reason for a tune.
Any thoughts? Is this not what compressor stall sounds like? Does it sound like a tune problem?
Old 06-28-2008, 04:53 PM   #8
WhiteH2O
Member#: 452
'06 GX470
Anyone? Should I look for all the smart people in another forum or something?
Old 06-28-2008, 04:57 PM   #9
flstffxe
Member#: 155358
2008 Forester
Steel Silver
^^give it time, it is the weekend, many people have stuff going on away from a computer.
flstffxe is offline   Reply With Quote
Turbo flutter? or compressor stall? shadysalezmen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-24-2009 07:13 PM
Intake Flutter? Compressor Stall? jlee27 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-12-2003 12:44 AM
BOV's/ Compressor stall what is a man to do nu2rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-16-2002 03:29 PM
Compressor stall problem I think. Also, is there a such thing a wastegate slap? knuckles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-19-2002 07:28 PM
turbo falltering or compressor stall? ZoomnWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-02-2002 03:27 PM
