Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 06-27-2008, 07:56 PM   #1
Member#: 148974
2010 STi Hatch
Default Spacer in propeller shaft mount
I have a problem;
Whoever was putting together this car didn't do a good job. All parts are technically OEM, except aftermarket headers and a K&N panel filter.
But, the problem is that the motor and tranny are pushed towards the back, and the transmission is pointed slightly downward. The car drives fine, with the exception of the shifter being too far back, and some noise where the exhaust is resting against the rear sway tower (dunno the technical term).
Dilemma; the propeller shaft mount (the part where the two pieces of the driveshaft meet, and there is a big rubber/metal joint) had a big fat spacer added to the mount bushings... so, in an attempt to lift the propeller shaft a little to make the angle less ever, I removed the spacer. Now I get a *clunk* when starting out in first, and sometimes while gassing it through a turn.
How do I find a happy median!?! Is there something else that I can do, so that I don;t have to put the spacer back where it shouldn't be?
SurfGuruJeff is offline   Reply With Quote
Beatrush Propeller Shaft mounts ray101381 Transmission (AT/MT) & Driveline 22 07-07-2010 07:40 PM
New Beatrush propeller shaft mounts-$50 shipped byroll01 Suspension/Brakes/Handling 2 07-07-2009 01:54 PM
STi Drive Shaft, Propeller Shaft ETC.. Bad Wagon Private 'Wanted' Classifieds 7 09-27-2004 10:25 AM
Propeller shaft compatability?? Wrx Vs. GC8 sube151 Transmission (AT/MT) & Driveline 7 11-23-2003 02:16 PM
Questions about propeller shaft FederalAuditor Transmission (AT/MT) & Driveline 4 05-14-2003 11:31 PM
