Old 06-27-2008, 09:12 PM   #1
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Can anyone running these cams please tell us how the power band has changed. Please post the turbo, engine setup such as 2.5, 2.0, stroker, what other head work performed if any, and changes in shift of power band. I just ordered these cams with the 70 lbs @ 35.5 seat Supertech daul valve spring kit including ti retainers and alloy spring seats.
methaddict is offline   Reply With Quote
Old 06-27-2008, 09:48 PM   #2
Member#: 111556
2006 STI
i have a full BC 272 setup, with BC valvetrain also. Going on my built, high compression 35r setup. Should be running within a month.
xerox445@yahoo.com is offline   Reply With Quote
Old 06-27-2008, 11:51 PM   #3
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
How's the quality of the BC stuff? I've seen people say it's really nice, and others have said they wouldn't use it.
MannyMohawk#5 is offline   Reply With Quote
Old 06-28-2008, 12:23 AM   #4
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
I've heard both also. I will wait to see what the final verdict is before I decide to use any of it. I will stick with proven names for the time being.
axelthrasher is offline   Reply With Quote
Old 06-28-2008, 12:27 PM   #5
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I had them in my 02 WRX, I didnt get to drive it for very long before I got hit head on. But I will say that the powerband was NICE. Lumpy as hell idle, but I think that was more from the thicker head gaskets. It sounded like a 60s muscle car (for real, lump lump lump)
Defiant Autospeed is offline   Reply With Quote
Old 06-28-2008, 09:35 PM   #6
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
Buddy of mine has them and says they're very much worth it. I'm rebuilding my motor with these cams too, should be done in about 5 more weeks.
toutanje is offline   Reply With Quote
Old 06-28-2008, 10:06 PM   #7
SL,UT_STI
Member#: 161458
1999 BLK 2.5RS
Swap in progress
im buying them as well for my build.. glad to hear good things about them
SL,UT_STI is offline   Reply With Quote
Old 06-29-2008, 09:16 AM   #8
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
They're waiting to be installed in my 2.0 heads for my hybrid build. I also chose the BC spings/retainers and BC stainless .5mm over valves. My valves are all flat face, which should help keep compression up since I'm opening up the chambers to match the 2.5 bore.
What I can't figure out is how to match the turbo to them. I want a turbo that'll maintain power at 7500 rpm. Will these cams let a smaller turbo produce more power at high RPM, or will they make it harder for a small turbo to keep up and require a larger turbo?
bluescoobywagon is offline   Reply With Quote
Old 06-29-2008, 03:47 PM   #9
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
You will need a larger turbo. With more air coming through cams will run a small turbo out of breath faster.
CoolRex is offline   Reply With Quote
Old 06-29-2008, 04:19 PM   #10
MRX WRX
Member#: 114566
2005 STI
aspen white
you must not have been around cars for very long...Brian Crower has been around for a loooooooong time, they know what they are doin. they have been making cams since the early 70's if not longer!! youve never heard of crower cams??
MRX WRX is offline   Reply With Quote
Old 06-29-2008, 04:28 PM   #11
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
You are thinking of Crower cams....not Brian Crower. Brian Crower is the son of the owner of Crower cams. Crower mostly focuses on non-imports and Brian focuses mostly on imports (although both do have some options in both fields). Brian Crower is fairly new.....compared to Crower.
Old 06-30-2008, 10:21 AM   #12
methaddict
Member#: 159738
2004 WRB STi
BC says it'll move the power band to the right 500-800rpm with hp gains of 30hp
Old 06-30-2008, 10:37 AM   #13
SUBARU RALLY GUY
Member#: 162046
97 Legacy wagon
just wait and see
Delta has these profiles for way le$$
SUBARU RALLY GUY is offline   Reply With Quote
Old 06-30-2008, 10:41 AM   #14
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Links to proven results and people using them?
Old 06-30-2008, 01:30 PM   #15
railguy
Member#: 53756
6 months from now when my eg33 is running, I will post results from these guys. They are the real deal.
railguy is offline   Reply With Quote
Old 06-30-2008, 01:34 PM   #16
MRX WRX
Member#: 114566
2005 STI
aspen white
its his son, you dont think he knows about cams? thats the point i was making, he is not a newbie to cams, they just branched out into another division
Old 06-30-2008, 01:36 PM   #17
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Still not the same. I've seen BC cams snap in half in person but I personally think that was due to an install error by one of the shop guys.
Old 06-30-2008, 02:14 PM   #18
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I experimented with big cams and head work and small turbo and found that when the turbo is out of air all the cams and headwork in the world won't make up for it. I can post up more data when I get off work later but my setup is Cosworth cams, DPR heads, and a Greddy 18G. Its fun but the turbo is way out of effeciency range shortly after 5K rpms.
And here is a link: http://forums.nasioc.com/forums/show....php?t=1475015
Old 06-30-2008, 04:27 PM   #19
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Non AVCS cams are going to be much lumpier than AVCS cams of the same duration because they have more overlap at idle. The HG doesn't have anything to do with it.
Old 06-30-2008, 05:14 PM   #20
bluescoobywagon
Member#: 14911
Not A Wagon!
Very useful information! Did you upgrade your turbo yet? I'd love to see a 3rd line with an upgraded turbo and no other changes. It's interesting that the cams can increase high rpm power, but only if the turbo can flow it. At redline your cams and headwork only gave you a couple horsepower, but in the midrange you picked up 40 or so hp!
Old 06-30-2008, 06:17 PM   #21
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I was looking at the ATP 3076 but they told they would be releasing the 3076 with a new integral Tial wastegate flanged hotside. I may wait for that.
Old 06-30-2008, 07:09 PM   #22
fastlanerex
Member#: 133391
2004 boosted saleen
white
Dont mistake (Crower) with (BrianCrower) two totally different companies.
fastlanerex is offline   Reply With Quote
Old 07-01-2008, 08:20 AM   #23
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
^^^^Already said that above.
Old 07-01-2008, 02:02 PM   #24
methaddict
Member#: 159738
2004 WRB STi
Well it seems no one has it in their cars yet?
Old 07-01-2008, 02:05 PM   #25
rainwrx
Member#: 68955
2005 WRX Hybrid
Needs Paint
Had a friend recently with BC cams -- one had snapped in half within the first 300 miles -- don't think it was install error.
rainwrx is offline   Reply With Quote
FS : CA: Brian Crower 272 CAMS (Stage 2) - ej257, BC Titianium Spring Retainer Kit Evilchargerfan Engine/Power/Exhaust 35 09-27-2010 11:20 PM
FS OH: EJ205 Brian Crower 272 Cams wrxcop4 Engine/Power/Exhaust 7 07-13-2009 12:25 PM
Built WRX Ported Heads + Brian Crower 272 Cams urlosn Engine/Power/Exhaust 21 01-01-2009 07:11 PM
Built WRX Ported Heads + Brian Crower 272 Cams BC urlosn Engine/Power/Exhaust 7 12-23-2008 09:05 AM
