Old 06-27-2008, 11:10 PM   #1
2slofouru
Member#: 90539
Default stock L radiator or 02 wrx radiator for ej20k swap?
I recently purchased a new 02 wrx radiator for my swap. My main problem will be the top hose and fans. I may be able to use my L fans since this radiator is so thin. If not, aftermarkets will probably go on. I mainly bought the wrx radiator because I wanted to lose one radiator cap and gain the small nipple on the passenger top side for the coolant tank. I also have a set of silicone hoses for the 20k setup but they are geared for the 97 jdm gc8 radiator and the top one is just like my L. I also can't seem to find any diagrams showing the hose routing for the metal coolant tank.
-what's the best solution for the upper coolant hose lining up, wrx or L radiator?
2slofouru is offline   Reply With Quote
Old 04-16-2009, 10:54 AM   #2
2slofouru
Member#: 90539
I'm using my L radiator for now, the wrx upper tube is way off, don't want to rig it. Its also the same thickness as the L radiator so kind of pointless to use. The L fans also fit, barely rubbed on the passenger side so I cut the corner off the fan cage... piece of cake. So now I have two slim 12" fans and a new koyo oem type 03 wrx radiator that will be for sale.
T-hose needed for 02 WRX radiator swap...need help TGC Service & Maintenance 1 12-10-2009 12:28 AM
07 STi rods, 02 WRX radiator, WRX Intercooler, Turbo inlet + stock pipe livestrong14 NWIC Private Classifieds 2 11-07-2009 09:53 PM
02 WRX Radiator Busted, Swap question XITruthIX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-17-2008 05:42 PM
02 wrx harness for your swap.... serious Engine/Power/Exhaust 0 03-31-2008 08:17 PM
02 wrx crossmember for 6sp swap? fastnoypi Transmission (AT/MT) & Driveline 2 07-20-2006 08:01 PM
