Old 06-27-2008, 09:50 PM   #1
front runner
Member#: 121603
2001 legacy BH
blue
Default Sti A and B grade pistons?
Does anyone know the difference between A and B grade pistons? To me, they look exactly the same and the search button isn't helping. I have a new set of oem's that I got for cheap and I don't want to put them on the wrong sides.
front runner is offline   Reply With Quote
Old 06-28-2008, 01:26 AM   #2
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
The difference is the actual size. I think Subaru did this to compensate for machining differences in the bores. The cylinder bore size is stamped on the block's front upper surface.
The "B" piston has an outer diameter of 3.6211 to 3.6214 inches
The "A" piston has an outer diameter of 3.6214 to 3.6218
This way you can select an "A" or "B" piston to get the correct piston to sidewall clearance. Measure the bore, do the math, and select the correct piston for that bore.
I'm reading this right out of the FSM for the STI. I bought it for my upcoming sti short block with EJ20G or 2.5 N/A heads motor.
Hope this helps!
morrocco88 is offline   Reply With Quote
Old 06-28-2008, 01:33 AM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
holly **** are you serious? I didn't know they had this. thats actually pretty good of subaru to do that. this way you are not just buying an "off the shelf" piston, and hoping it fits !
BTW, you will get WAY more responces in built motor forum.
IllNastyImpreza is offline   Reply With Quote
Old 06-28-2008, 03:36 AM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I just marked mine when I rebuilt my current motor, that way you could compare them to your new ones.
~Josh~
ballitch is offline   Reply With Quote
Old 06-28-2008, 01:44 PM   #5
front runner
Member#: 121603
2001 legacy BH
blue
Thanks for the info! I had no idea that what those markings meant. now I can build without that looming over my head
Subaru FACTORY Pistons come in three sizes and 2 grades!! Get them at Draco! Draco Performance Engine/Power/Exhaust 2 04-07-2010 04:05 AM
Building my sti block, and suggestions for pistons and rods? wrxwagon253 North West Impreza Club Forum -- NWIC 5 11-25-2007 02:08 AM
FS VA: 04 STi Rods and pistons, and Perrin Lightweight crank pulley billy720 Engine/Power/Exhaust 4 06-15-2007 01:01 PM
2.5 STi short block and 6 new pistons ,rings and wrist pins LiquidForce Private 'For Sale' Classifieds 6 07-13-2006 07:44 PM
04 WRX STi parting out(ProfecB,Forged STI Rods and Pistons,TMIC,STi injectors...) billy720 Private 'For Sale' Classifieds 4 04-18-2006 02:11 AM
