Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 06-28-2008, 03:24 AM   #1
brian231
Member#: 182390
Default Help needed with keyless locks
I have a 2006 Forester w/ 38k miles. The driver side door lock and the rear tail gate simultaneously started acting flaky.
I get 12 volts out of the integrated module for the driver side actuator, the passenger/gate actuator, and the common actuator when operating the buttons. When I lock/unlock the doors I can feel the rear gate motor/driver side motors attempting to lock/unlock but they often can't quite make it.
If I send 12 volts to lock/unlock the driver side door I get a weak lock. If I send 12 volts to the the passenger doors they lock/unlock fine. The rear gate is somewhat flaky.
Any ideas of whether I have:
1) Bad car battery? (The car starts fine, but the battery hasn't been replaced)
2) A bad integrated module?
3) Two bad actuators?
4) Wiring harness problem?
Thanks,
Brian
brian231 is offline   Reply With Quote
Old 06-28-2008, 03:49 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The actuators or the lock mechanism may be sticking and need some oil. Also make sure the ground to them is ok.
Old 06-28-2008, 02:04 PM   #3
brian231
Member#: 182390
I don't think they're actually grounded though. They actually have two wires so the polarity can be flipped when locking/unlocking.
Old 06-28-2008, 10:38 PM   #4
Cougar4
Member#: 53443
Winestone
Yes that is true, but a ground still has to be made through the switch.
Old 06-30-2008, 01:41 AM   #5
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
it wouldnt be a bad idea to do a voltage drop test, while operating the locks, from the module to the actuator should be less than .2 volts. also perhaps grease the actuator and or the locking mechanism itself? White lithium FTW
ProdriveDreams is offline   Reply With Quote
need help! TT with Keyless entry? artdoesart Newbies & FAQs 1 01-21-2004 10:08 PM
Help Needed with my STI cluster STAT! adamsrs General Community 9 11-07-2001 10:10 PM
Urgent help needed with 91 Acura Intake. munkis General Forum Archive 12 01-01-2001 03:37 PM
Help Needed with i Club FAQ. Imprezer General Forum Archive 47 10-11-2000 08:00 AM
Help needed with digital video survey wac New England Impreza Club Forum -- NESIC 14 05-10-2000 05:57 AM
