Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 06-28-2008, 05:41 AM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default normal to have dip in oil press?
Guys, whenever ive come to a traffic light, i slow down, press the brakes and engine brake. However, when coming to a complete stop and depressing the clutch pedal, the oil press and rpm will certainly dip to about 1 bar before rising up to 2 bar (standard idle oil press). This happens when i manoeuvre at low speed in the case of tight areas and parking. Is this normal?
jacky599r is offline   Reply With Quote
Old 06-28-2008, 05:28 PM   #2
WhiteH2O
Member#: 452
'06 GX470
My car has started doing this a little and it didn't used to. I have my defi guage warning set at 20psi and the light and warning sound occasionaly come on for a fraction of a second on and off at a stop light. I was thinking of asking the same thing. Bump for and answer.
WhiteH2O is offline   Reply With Quote
Old 06-28-2008, 10:39 PM   #3
WhiteH2O
Member#: 452
'06 GX470
Maybe a little bit of a warning to you jacky.
I just found what looks to be an oil leak in my turbo. Blowing white smoke all over the place. Thinking that the low oil press may have been a sign that something was about to happen.
Question for everyone else: What oil press do you have when idle and clutch in with the car warm? I don't remember what mine used to be, but I almost recal 40psi-ish being standard.
Old 06-29-2008, 03:19 AM   #4
jacky599r
Member#: 137631
2006 WRX
Red
geeee....
im having white smoke on start ups....do i see a link or something? the turbo has very little mileage on it. damn! i dont wish to jump into a bad conclusion but i cant help it.
Gurus?! chip in pls.
p.s: it just stalled yesterday when im reversing to park
Old 06-30-2008, 06:18 AM   #5
jacky599r
Member#: 137631
2006 WRX
Red
need more info
Old 06-30-2008, 12:50 PM   #6
charliew
Member#: 125304
You didn't state what viscosity you are using. The temp of the oil will affect the pressure quite a bit. Also old diluted oil will have lower pressure.
charliew is offline   Reply With Quote
Old 06-30-2008, 01:02 PM   #7
dmross
Member#: 2818
2000 2.5RS
There are a multiple things that can cause this:
1. low RPMs - when coming to a stop, your RPM's might drop below the idle point (tuning issue) and oil pressure will drop for a split second because your RPMs are too low
2. diluted oil - how old is it? does it smell like fuel? is there coolant in it?
3. wrong viscosity - are you running too light for your setup?
4. bearing damage - are you seeing lower oil pressure under load as well? metal shavings in the oil filter?
dmross is offline   Reply With Quote
Old 06-30-2008, 10:40 PM   #8
jacky599r
Member#: 137631
2006 WRX
Red
woo.
the motor has 2500km after built. It has been spewing smoke on start ups.
Slightly high CR after built with oversized pistons (yet to tune)
Oil is 15w40 castrol gtx modern engine dino as im still breaking it in. I change em quite frequently. This is the 3rd oil change that im running and the first one is 5w50 ows dino and the oil is in the midst of sending to blackstones for testing.
How can i really check for shavings? Ive the first oil change oil filter with me... looks like theres something around the filter element as i run through my fingers against it and i can feel some coarse particles. Dont know what is it though.
O, some ppl pointed out that it might be a bad turbo seal too of which i have clocked little miles too.
Old 07-01-2008, 08:04 PM   #9
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
where is your sensor located? I had mine on the sandwich plate and would see 90-95 on the highway,115 at the track, and 25 at idle warm with 10-30 redline (104k 2.0) Then I changed to the upper oil galley and its about 3-5 psi lower and waivers a bit when you roll into the throttle or cruising on the highway. My tech says its b/c that spot gets air in it and is not accurate for pressure. Next oil change it will be going back to the sandwich plate.
with a new motor you will have some brass in your oil for the first few thousand miles (break-in)
scby rex is offline   Reply With Quote
Old 07-04-2008, 03:52 AM   #10
jacky599r
Member#: 137631
2006 WRX
Red
damn it...
first crank of the day... car sounded way weird, it was as if i have got myself a sets of race cam. RPM was hunting a little...but OIL PRESS were hunting way beyond the daily parameters. Car felt weird, is as though the clutch is slipping or that sort. Engine was vibrating like hell. Smelled weird too... Popped the hood, checked the dip stick and hell the oil level was half an inch lower and now sticks between E and F!
As im going to be late for work and thinking that it was alright, I drove it vvvv lightly in hope that the car will be better after warmed up. It din, and i saw the CEL flickered many times!!
Now the car is parked and im gonna go to the garage but before that...video shoot again so that i can capture the entire scene and show it to u guys for better diagnostics.
Old 07-04-2008, 06:10 AM   #11
jacky599r
Member#: 137631
2006 WRX
Red
alright, got it checked out and it was p0302 cylinder 2 misfiring. put back a old stockie plug and everythings fine.
Back to the oil dip, since the car has been resetted, the dip is even more frequent now.
Old 07-04-2008, 09:35 AM   #12
dmross
Member#: 2818
2000 2.5RS
Sounds like you have multiple issues. It might be a good idea to check for bearing damage.
Take your oil filter off and get some tin-snips and cut it open. You should be able to remove the filter element entirely and stretch it out. Look for metal shavings. Hopefully there won't be any and your problem lies elsewhere.
Old 07-04-2008, 09:37 AM   #13
dunk
Member#: 15359
I think you also need to do a compression check to cover your bases. Look at the plugs carefully too.
Duncan
dunk is offline   Reply With Quote
Old 07-06-2008, 01:32 AM   #14
jacky599r
Member#: 137631
2006 WRX
Red
i actually have a oil filter left over from the first oil change... it has some metal like particles really.... few but i dont know whats the limitations to damage bearings. im still waiting for my oil analysis to be out (hope it can provide me good insights).
I can snap a pic of the filter and plugs if u guys can help me out here.
Old 07-06-2008, 05:22 PM   #15
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
A 100% atmospheric bov will cause the idle to drop when you let the clutch out. It makes my defi oil pressure gauge bleep for a quick second once in a while.
Honest Bob is online now   Reply With Quote
Old 07-07-2008, 12:30 AM   #16
jacky599r
Member#: 137631
2006 WRX
Red
hmm, im on a forged 100% recirculative
Where to have a wheel bearing pressed?? NexRex Texas Impreza Club Forum -- TXIC 4 03-23-2010 02:27 AM
Normal to have a dry catch can? jmeltzer4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-13-2009 10:41 PM
Is it normal to have large oil deposit on air filter @ 24K? atlblu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 03-26-2008 10:39 AM
Normal to have to calibrate wideband after 3 weeks? JDM 3SGTE Engine Management & Tuning 12 12-29-2005 08:30 AM
1/8PT to 1/8NPT conversion - OIL Press. (DEFI)?? Mrfairlady Interior & Exterior Modification 1 05-26-2005 02:07 AM
