Old 03-04-2002, 02:59 AM   #1
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
Question location of some sensors on the MY02 factory ecu harness. . .
Hey guys, I'm installing my HKS CAMP system this weekend and I need to know which wires going into the factory ECU are for the speedo, tachometer, and injector duty cycle sensors. Constant 12V power (for memory) and power on ignition would be nice as well, so I can keep from running wires all over the place.
I have instructions for the CAMP, but it's all in Japanese so it's somewhat difficult to discern which wire goes where. I figured out which wire is which coming from the unit, but I'm not sure about the ones on the Subaru ECU.
Thanks!
JD
wackie is offline   Reply With Quote
Old 03-04-2002, 03:47 AM   #2
WRX Power
Member#: 7142
try http://www.northursalia.com/m...ng/wrxpin.html
I had a better one that was color coded and everything but it is on my other hard drive that is partially crashed.. maybe I can recover it. We'll see. But this chart works just as good.
-Bryan
WRX Power is offline   Reply With Quote
Old 03-04-2002, 07:47 PM   #3
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Default Re: location of some sensors on the MY02 factory ecu harness. . .
Originally posted by wackie
and injector duty cycle sensors. JD
There isn't a "injector duty cycle sensor." I assume you mean the CAMP will compute injector duty cycle if you give it one of the injector driver lines, which are grounded by the ECU to turn the injector on?
-Jeff
sponaugle is offline   Reply With Quote
Old 03-04-2002, 07:52 PM   #4
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
Yup sorry, poor wording. From what I can tell the CAMP unit makes the duty cycle computation based on user-provided injector characteristics and an offset or multiplier based on the voltage range from the ecu.
location of MAF sensor on 02 TS dlong27 Normally Aspirated Powertrain 3 05-29-2009 01:20 PM
Test fit of some Prodrives on the RSTi "GC8" OneArmedScissor Member's Car Gallery 4 05-05-2008 12:39 AM
location of O2 sensor (bank 1, sensor1) dingo dave Service & Maintenance 2 03-10-2003 06:57 PM
Location of airbag sensors zmog Legacy Forum 2 03-03-2002 02:34 PM
Location of Speed Sensor Wire tsdrally North West Impreza Club Forum -- NWIC 1 04-29-2001 10:46 PM
Message Board Statistics All times are GMT -4. The time now is 11:54 PM.
