Old 06-28-2008, 12:46 PM   #1
WRX_scott
Member#: 51458
2003 WRB WRX 04 Conv
2.5L/Hydra/6spd/FMIC
Default BC cams 272 or 280
I am looking at getting Brian Crower cams for my build. Currently I have a 2.5L waiting to go into my WRX. I plan on going with USDM STi heads or Spec-C heads. I cant decide between the 272 or 280 cams. Does anyone on here have experience with these cams? I am aware there is a little lope due to the cams but I am also planning on going with Hydra.
Setup:
Rotated 35R
2.5L built
STi or Spec-C heads
JDM Spec-C intake manifold
PPG gear box
Hydra
other support mods...
WRX_scott is offline   Reply With Quote
Old 07-08-2008, 02:46 AM   #2
86ray86
Member#: 172069
280's for a 2.5 will give the best gains and will have very good top end.. 272's are for 2-2.4 imo..
86ray86 is offline   Reply With Quote
Old 07-08-2008, 12:48 PM   #3
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
I thought BC cams came in 274, not 272? might be wrong though...
Jpizzzle is offline   Reply With Quote
Old 07-08-2008, 01:33 PM   #4
WRX_scott
Member#: 51458
Well I have thought about it and I am still not sure if I want to use STi or Spec-C heads. I would like the benefit of AVCS (dual would be nice) but I like the idea of saving money and using my stock 2.0 heads on the 2.5l and getting them ported and cams. What do you all think?
Scott
Old 07-08-2008, 01:40 PM   #5
alex02wrx
Member#: 169196
2002 Impreza WRX
Sedona Red
I have the 272's and they have a nice smooth lope. I wish I could tell you how the top end performs but Im still in the break in process. Im running A Blouch Dom 3.0R, 2.5L, PnP 2.0 heads, BC Valves, Springs, & Retainers.
alex02wrx is offline   Reply With Quote
Old 07-08-2008, 10:02 PM   #6
aaron04
Member#: 146569
2009 A4
280 cams will not be good for a street car. unless you want to idle at 1500rpm
aaron04 is offline   Reply With Quote
Old 07-08-2008, 11:32 PM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Advertised duration != actual duration or duration at .050.
One manufacturers 272s may be bigger, better and badder than anothers 274s. Different manufacturers use different checking heights to come up with the best ""marketable" duration.
Old 07-08-2008, 11:38 PM   #8
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Definitely something to consider... idle speed... It gets old rather quickly having your idle sit so damn high on a daily driver.
jigga is offline   Reply With Quote
Old 07-09-2008, 05:40 AM   #9
WRX_scott
Member#: 51458
Good point Jigga, also raises the exhaust note that will be emitted from the car as well and we all know we dont want the attention of the cops.
Old 07-09-2008, 06:39 PM   #10
alex02wrx
Member#: 169196
2002 Impreza WRX
Sedona Red
My Idle On the 272's is at 900-1000 RPMS with my break in tune.
Old 07-09-2008, 08:01 PM   #11
Kaldar142
Member#: 151090
S197 boosted V8 FTW
how would 272s do on a 2.0 car that is used for autox?
or what cams would i use for for low / mid range but still good top end, basically a good powerband?
sorry to hijack :P
Kaldar142 is offline   Reply With Quote
Old 07-12-2008, 04:23 AM   #12
86ray86
Member#: 172069
i have 280s and mine idle no where near 1500, idles at 1000, comes down to how well the tuner can tune really...
Old 07-12-2008, 11:04 AM   #13
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
Not true. There are ways around this. I have 280*'s on my built 2.0l. It's just a matter of the motor getting enough air to stay running at idle. I just cracked my throttle body plate and it idles fine around 1000-1200. Lopes its ass off though. Car cuts off if I abruptly let off the gas every once in a blue moon... but not often. My car has ridiculous topend... but different build.
japslapr is offline   Reply With Quote
Old 07-13-2008, 04:33 AM   #14
blue05
Member#: 125144
2005 wrx STi
wrb
with a higher duration cam will there be any clearance issues with fully advanced avcs? the usdm heads only advance 20 degrees, the jdms I believe advance 40. the 272's have a 10.14mm lift, or something close to that. the 280's have 14.5 i think. does anyone know if you can run full advance with the larger cam? I would be very nervous to run the 280 not knowing if the valves will have the chance to touch the piston.
blue05 is offline   Reply With Quote
Old 07-13-2008, 10:07 AM   #15
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
you have usdm 03 wrx. this ecu does not support avcs.
you could try to have a jdm/edm rom file flashed onto your
ecu & some wiring modifications. if that doesn't work you could
get 04 sti ecu & engine harness. but guess you'll have to weigh
your options..cost/time..all this to get avcs cams to work properly
then you say hydra...well how much does it cost?..1500~2000?
Old 07-13-2008, 02:45 PM   #16
WRX_scott
Member#: 51458
I know what I have and know what my car is capable of. That is why I am doing the research now regarding the pros/cons of using my EJ20 heads vs. AVCS heads.
Old 07-13-2008, 05:34 PM   #17
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
no doubt the car shakes noticeably from side to side also while inside the car..
Old 07-14-2008, 10:40 AM   #18
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You can do that, some people drill a small whole in the TB plate. There are ways to get around it but you said it yourself, the return to idle sometimes sucks stalling out every so often. Not a big concern for you or I but not the most friendly DD either.
New in box: Brian Crower BC Cams 272 BC0601 subypal Engine/Power/Exhaust 4 05-31-2010 09:20 PM
05 STi, BC cams, turn off avcs or use wrx gears Sinister redlines Built Motor Discussion 10 12-01-2009 08:57 AM
used 272 bc cams truckco5 Private 'Wanted' Classifieds 0 01-07-2009 12:44 AM
fs or ft: bnib bc cams quikie SCIC Private Classifieds 3 09-05-2008 05:26 AM
bc valvetrain or bc cam and supertech springs and valves LoganG1K Built Motor Discussion 4 06-16-2008 11:42 AM
