Old 06-28-2008, 06:47 PM   #1
parkes
Member#: 166898
1994 T leg SS
ABM
Default 440cc-EJ22-Small 16G-Max fuel?
Hello Guys and gals i got a quick question for you.
Im Currently in the Stage of a build, I have a 1994 subaru legacy turbo that will be getting a moter soon.
Its is an EJ22T Closed Deck Moter Hybrid with Ej25 Heads and manifold.
Will i max out my 440cc Injectors with a small 16 G on this EJ22.
Its Got an 07 STI fuel pump. I want to boost somewhere conservative between 12-17. Will i max them out at 17? Or Will engine managment solve my problem?
parkes is offline   Reply With Quote
Old 06-30-2008, 05:24 PM   #2
Drakar
Member#: 68402
Legacy
check out bbs.legacycentral.org youll max out I believe the MAF before those injectors, but they can tell you for sure.
Drakar is offline   Reply With Quote
Old 06-30-2008, 08:26 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
yes you will max out injectors.
factory vf-22 came with pink 550cc injectors.
16g flows close too vf-22..
you might be able to sneak by if you had water/meth.
STI fuel pump (2006) with small 16g jacbri Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 08-23-2008 05:52 PM
small 16g max power silverstreakwrx Proven Power Bragging 65 06-21-2008 04:49 PM
Ready to Ship Blouch Evo3 16G Turbos and Small 16g Turbos!!! Spun Autosports MAIC Vendor Classifieds 2 08-20-2007 12:10 PM
lots of compressor flow maps, small 16g, large 16g, and 18g prometheum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-10-2006 02:21 AM
small 16g vs big 16g silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 01-10-2006 02:51 AM
