Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 06-28-2008, 07:47 PM   #1
armigerlives
Member#: 180958
2008 Homemade
Yellow
Cool 2.5 SOHC swap, doesn't weant to idle when warm
Heya, I performed a swap in the car I built from scratch about a month ago. The harness and ECU are out of an '93 impreza and the engine is from an 2000 outback. i am using the 2.5 coil/ignitor, i just bypassed the old separate ignitor that the 1.8 used. I am using the 1.8 throttle body mated to the 2.5 intake manifold via an adaptor I madeout of 20guage sheet steel. The engine runs real strong but when it is warm it doesn't want to idle when I stop. I tried adjusting teh set screw on the throttle body but I think the computer keeps overiding it. Any Ideas?
Here are some videos of the car, as well as some pics;
http://www.cardomain.com/ride/3088011
http://video.cardomain.com/armigerlives
Thanks!
armigerlives is offline   Reply With Quote
Old 06-30-2008, 03:16 PM   #2
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
You've probably already done this but first check for vaccuum leaks.
Next I'd check the Idle Control valve/actuator, make sure that's working as it should.
jey is offline   Reply With Quote
Old 06-30-2008, 06:22 PM   #3
armigerlives
Member#: 180958
2008 Homemade
Yellow
ya That was the first thing I checked for, the IAC is definitely a possibility seeming as to how it is placed differently than the one on the 2.5 throttle body. I am going to swap the computer with one from an '93 2.2L and see how that effects things. The 2.2 has a 6500rpm rev limit as opposed to the 6k limit the 1.8 had. I think it might match the 2.5 a bit better.
Old 06-30-2008, 06:28 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If its anything like the old IACs then it has a heat spring inside that closes off an extra air passage as the car gets warm. I'd try to open up the bypass screw on the TB to increase the warm IDLE and see if the cold idle can still be compensated for by the electronic portion of the IAC.
Old 06-30-2008, 09:27 PM   #5
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
i have an iac sensor with about 10k miles if u need it, bought new from subaru for 350
Old 07-02-2008, 08:29 AM   #6
armigerlives
Member#: 180958
2008 Homemade
Yellow
Thanks, adjusting the screw didn't effect anything except the idle in park and neutral. I have about 5 slightly used IAC's on other 1.8l engine and about 3 sitting on 2.5l engines. When I did the swap I didn't change the fuel pressure regulator from the 1.8 to he 2.5, I think I might do that.
Old 07-02-2008, 05:27 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Leave the IAC attached as normal but remove the electronic portion on top and turn the shaft by hand and see if it is able to change the idle.
Old 07-04-2008, 12:29 PM   #8
armigerlives
Member#: 180958
2008 Homemade
Yellow
The problem is that it will idle fine when it is in park or neutral. When it is in gear and I am stop at a light idling in gear it doesn't want to. Engine bucks, when I remove the wires from cylinders 1&3 it makes no difference (engine doesn't bog). Cylinders are getting spark, and fuel. As soon as you start to move it is all smooth, there is no missing. Any ideas? BTW I'm going to check the coil to see if that is the problem, just because I am getting spark doesn't mean it is "good" spark. Also the spark plugs are new. Was idling ok but got gradually worse. Thanks for any ideas on other possiblilities.
Old 07-04-2008, 07:20 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
So its an automatic? There is a small chance its the torque converter lockup malfunctioning. Once a month or so one of my Legacys does this and the car nearly dies before it finally unlocks.
Old 07-05-2008, 01:06 AM   #10
armigerlives
Member#: 180958
2008 Homemade
Yellow
definitely not a converter locking up. I checked today and I think i'm not getting fuel to 1&3 while at idle
Old 09-25-2008, 10:01 AM   #11
armigerlives
Member#: 180958
2008 Homemade
Yellow
Woot i finally figured it out. I had a bad ground from the Neg side of the battery to the frame. It ended up frying the computer. Since the injectors are high output they were the first things to have problems.... turns out I wasnt getting anything from the ecu to #3 injector. Re grounding the battery to the frame with a very good solid connection, then replacing the ECU (i happened to have another one lying around) fixed the issue. It now runs like a raped ape and idles smooth. Thanks for your imput
Please help me!! 2.2 sohc to 2.5 dohc swap problems! lomaxmotorsports Normally Aspirated Powertrain 7 07-19-2008 01:29 PM
2.5 DOHC swap to 2.2 SOHC compatibility? suby53 Normally Aspirated Powertrain 9 01-30-2008 07:28 PM
engine swap 2004 2.5 sohc to 2000 2.5 sohc rickinne General Community 4 06-08-2006 06:29 PM
2.5 DOHC --> 2.5 SOHC swap. Please Help! spdracr00 Subaru Conversions 13 03-02-2006 05:49 PM
2.5 DOHC --> 2.5 SOHC swap. Please Help! spdracr00 Legacy Forum 3 02-26-2006 09:38 PM
