Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 06-29-2008, 01:17 AM   #1
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Default HVAC Troubles
Some time last week my HVAC system in my '05 STi started behaving strangely.
I noticed that when I started the car, the outside temperature gauge would read a ridiculously high temperature, like 122 degrees. Sometimes it will drop to a more realistic temperature later, sometimes not. Then I realized that the AC was no longer blowing cold when set to "Auto." I played with the dials, and the only way I can get it to blow cold (and it's ice cold) is by turning the temperature dial all the way counterclockwise (below 65 degrees.) Combining this with the manual setting for fan speed, I can regulate the temperature comfortably... But it's annoying!
I'm inclined to think that the malfunctioning outside temperature gauge is in some way involved in the HVAC system no longer working properly. Does anyone know how I can troubleshoot this?
RP31 is offline   Reply With Quote
Old 06-30-2008, 01:51 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
well the HVAC unit does use input from the outside temperature sensor so it could be the culprit.
Something to keep in mind while trying to figure out this problem is how this system functions. The outside temperature sensor is not as simple as just sending sensor temps, the computer doesnt use input from this sensor if the car was on in the last hour, instead it uses the last valid reading it got. When the vehicle speed very slow (I believe it was below 1 MPH) the computer continues to use the last reading from before you slowed down. this may or may not play a role, just something to think about as far as noticing when it reads high.
Get a hold of a diagram and start tracing the wires looking for trouble. I can send you an E-Mail with the diagram for this system if you PM me your email.
ProdriveDreams is offline   Reply With Quote
FS socal: Center console, arm extension,hvac bezel, hvac controls snowcrzy Interior/Dressup/Audio & Security 7 09-14-2009 08:16 PM
02 HVAC swapped with 05+ auto HVAC Loomin Interior & Exterior Modification 14 01-04-2009 03:22 AM
Swap TR HVAC for a WRX HVAC? PiNPOiNT Electrical & Lighting 4 11-25-2008 07:15 PM
WRX Dash, Bar, HVAC Controls, HVAC ducting, Console, Glovebox, Silver Trim - $400 gedwrx Interior/Dressup/Audio & Security 7 03-18-2007 05:33 PM
