Old 06-29-2008, 01:12 PM   #1
jstam
Member#: 103489
2003 WRX
Undetermined
Default tgv deletes...
im about to do some deletes. i was wondering the best way to go about this... should i just use carbide to sut out that plate, or would a drill press work? any info would help. thanks.
jstam is offline   Reply With Quote
Old 06-29-2008, 03:07 PM   #2
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
Kosmic is offline   Reply With Quote
Old 06-29-2008, 08:14 PM   #3
DTSTI
Member#: 129832
2005 STI
GT4094r
Originally Posted by Kosmic View Post
That thread makes it look so easy. when i took mine out of course the 4 screws that take off the flapper stripped. i just ended up drilling them out. My advise is make sure you dont strip those screws it alot easier when you dont drill it. I also just J&B welded the holes closed cheap and effective.
DTSTI is offline   Reply With Quote
Old 06-30-2008, 05:13 PM   #4
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
The reason the screws stripped is because they're designed to not fall out. The threads are pinched on the back. If you flip open the butterfly and cut the exposed threads off the back of the butterflies, the screws will come right out without stripping or shearing.
bluescoobywagon is offline   Reply With Quote
Old 06-30-2008, 08:44 PM   #5
DTSTI
Member#: 129832
2005 STI
GT4094r
Originally Posted by bluescoobywagon View Post
The reason the screws stripped is because they're designed to not fall out. The threads are piched on the back. If you flip open the butterfly and cut the exposed threads off the back of the butterflies, the screws will come right out without stripping or shearing.
That would of been help full to know. Makes sense though
Old 07-01-2008, 01:00 AM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
I figured it was too late to help you (unless you ever do it again), but I figured I'd mention it in case anyone finds this thread in a search.
TGV Delete Kit (Phenolic Spacers + TGV Delete Kit + Gaskets) Koji NWIC Private Classifieds 15 10-11-2009 12:23 PM
TGV Delete Kit (Phenolic Spacers + TGV Delete Kit + Gaskets) Koji Engine/Power/Exhaust 16 10-11-2009 12:23 PM
WTT: Topfeed TGV deletes for Sidefeed TGV deletes pirotlord Engine/Power/Exhaust 17 07-02-2008 07:32 PM
WTB: WRX TGVs or TGV Deletes beaviscih TXIC Private Classifieds 3 12-12-2007 09:14 PM
APS TGV Deletes OR Stock TGV 04WRX Tripinray Private 'Wanted' Classifieds 0 04-22-2007 10:33 PM
