Old 06-29-2008, 03:05 PM   #1
JohnST2k6k
Member#: 178465
2006 WRB STI
Precision Built and Tuned
Default Hardwiring to Clock
Hey guys I have been searching for over an hour. I have a V1 radar detector and I want to mount it to the middle of the windshield and then hardwire it to the clock in an 06 sti. I have been searching for hours and all i came up with was the one mounting it over the rear view mirror. Ifsomeoen can help me out it would be GREATLY apprecaited. Thank yOU!
JohnST2k6k is offline   Reply With Quote
Old 06-29-2008, 05:49 PM   #2
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
What's your question?
Old 06-29-2008, 07:18 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
You should be able to find the switched power lead to the clock by using a test light probe. It may even be marked on the clock PC board.
Old 06-29-2008, 08:37 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You can use the harness for the auto-dimming mirror which is present whether you actually have the optional mirror or not. The connector will be up in the headliner behind the map lights. The mirror harness has switched 12V, ground, and reverse signal. If you use this harness be sure to verify the function of the wires before you make the connections- it is possible to accidentally use the reverse wire instead of the accessory wire and this will result in the detector working only when the car is in reverse.
Old 06-30-2008, 09:33 PM   #5
JohnST2k6k
Member#: 178465
2006 WRB STI
Thanks mulder. I actually decided to just go to tweeter and have them do it. Im trying to work something out that the wire will be pretty close to the detector, and I do not want to do it right above the mirror, because of the dot matrix. I am going to Autox and i cant have it flying around hahah! Thanks again everyone.
Nuvi 350 GPS Hardwired to Auto-Dimming Mirror Power simonbsays Interior & Exterior Modification 9 08-26-2008 08:18 PM
Mini-USB hardwired to car. Superorb Electrical & Lighting 2 05-12-2008 10:20 PM
Wired defi control unit to clock harness... shoooter_j Electrical & Lighting 13 05-27-2005 10:25 PM
Radar Detector Hardwired to Cruise Control Switch eclip5e Electrical & Lighting 9 11-23-2003 08:35 PM
Help! Optimal shifting for WRX to clock < 6sec vulcan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-17-2001 12:56 AM
