Old 06-30-2008, 01:42 PM   #1
silverongold
Member#: 132599
02 impreza wrx
Default ethanol and anti lag?
so we all know the main problem with anti lag is the high exhaust temps that destroy turbos. an evo Buddy of mine says that ethanol has way lower exhaust temps, is it true? also would it still combust in the manifold to create anti lag but with lower temps and longer turbo life?
silverongold is offline   Reply With Quote
Old 06-30-2008, 04:31 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
tempereture is only part of the picture. The pressure spike/wave from the combustion process occuring in the exhaust is the main killer of the turbo and manifold. The temperatures weaken the metal.
Alcohol on a gasoline tune will have lower temps but taking advantage of the alcohol will require a retune and then temperatures should be back up to about/if not the same as gasoline.
Old 07-01-2008, 10:13 AM   #3
charliew
Member#: 125304
It takes more alcohol to make the same power so just the tune plus if your injectors can't handle the increased volume you might also need to ugrade them.
charliew is offline   Reply With Quote
Old 07-05-2008, 09:11 PM   #4
silverongold
Member#: 132599
02 impreza wrx
but can it create low end torque and lower exhaust temps? also will it combust in a manifold?
Anti Lag Faq: a lot you don't know and should. wherethefmi Engine Management & Tuning 6 08-12-2007 11:52 PM
UTEC and anti-lag REXLR8 Engine Management & Tuning 16 03-19-2005 07:10 PM
Anyone running an ignition with anti-lag yet? iceweazel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-06-2001 11:47 AM
anyone put anti-lag on their TEC-II patr Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-03-2001 12:13 PM
Anti-Lag???? Rubasu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-24-2001 07:50 AM
