Old 06-30-2008, 02:33 PM   #1
MS WRX
Member#: 117780
2004 WRX
Default Running EJ257 heads non-avcs
If i am wanting to run the 257 heads on sti block "non-avcs" so as to not switch ECU's can i just block off the oil holes in the intake cams or is there more that has to be done?
MS WRX is offline   Reply With Quote
Old 06-30-2008, 04:17 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
mick_the_ginge is offline   Reply With Quote
Old 06-30-2008, 04:21 PM   #3
MS WRX
Member#: 117780
2004 WRX
so thats all that needs to be done? for the STi heads, not just cams? cool
Old 07-01-2008, 11:38 AM   #4
Dom'sGurl
Member#: 150837
2006 Legacy GT
if you have complete ej257 heads (cams and all)
Just put the heads on the car with AVCS cam gears.
Or, plug the holes in the sti cams.
that's it!
oh and I forgot one thing, you are going to need the cam sensor adapter that cosworth offers.
I know someone else makes one as well.
http://www.cosworth.com/shop_item.php?productid=523
Dom'sGurl is offline   Reply With Quote
NON AVCS cams and EJ257 heads ADJ cam sprockets saintluciascooby Built Motor Discussion 12 01-23-2012 09:12 PM
Directions how to install AVCS heads in a non AVCS car and not use AVCS sgiord86 Built Motor Discussion 1 11-19-2009 04:31 PM
AVCS Heads on Non-AVCS blocks. readymix Built Motor Discussion 43 03-27-2009 10:30 PM
WTB: Complete STI heads, Non-AVCS prefered Broxma Private 'Wanted' Classifieds 2 04-19-2008 03:12 PM
Limitations of EJ257 heads/ AVCS cams? Anyone with built heads here?? BigJ04STi Factory 2.5L Turbo Powertrain 16 02-08-2006 06:26 PM
Message Board Statistics All times are GMT -4. The time now is 08:02 PM.
