Old 06-30-2008, 05:14 PM   #1
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
Default how to tune for injectors
I do not know much about tuning. I got an online tune with my 650cc injectors but i want to try putting my stock injectors in. what would i need to edit in my tune to compensate for this and make sure its right? car is an 07 sti.
b0nd18t is offline   Reply With Quote
Old 06-30-2008, 08:42 PM   #2
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Fuel injector scaling and latency
robbieshonda is offline   Reply With Quote
Old 07-01-2008, 01:42 AM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
injector flow is 565cc and i forget what latency is for those... I'm not near my tuning PC right now, ill check later if no one gets back to you.
ProdriveDreams is offline   Reply With Quote
Old 07-01-2008, 08:24 AM   #4
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
Thanks!
guess i could just load my stock map, or gabes stage 1, to find them now that I think about it
Old 07-01-2008, 04:08 PM   #5
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
just be sure that the tune doesn't actually need those bigger injectors. Changing the scaling will make the fuel trims work, but won't help if the injectors are pegged at 90% duty cycle.
AruisDante is offline   Reply With Quote
Old 07-07-2008, 01:40 AM   #6
Beam
Member#: 29742
2011 STI
15 S1000R
What about tip-in throtle enrichment? I changegd the scaling and latency, but now there's a bit of a stumble when I jam the throtte. Should I reduce the tip-in by the same percentage as I incresaed injector size? In other words, the new injectors are 57% bigger; should I reduce the tip-in by the same percentage?
Additionally, the idle is rough when coming off throttle.
I swapped stock injectors for DW 840s. Additional Mods: TGV delete, ported intake and TB, Tomei exh. header and 3" exhaust.
I'm still on the stock turbo as I want to figure out this tuning thing before putting in a bigger huffer.
Beam is offline   Reply With Quote
Old 07-07-2008, 04:52 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Beam,
Do you have a wideband? If not you shouldnt be playing around with the fueling tables.....
To answer your question, yes you can reduced the tip in enrichment table.....IIRC I cut mine almost in half after doing the TGV deletes.
Old 07-08-2008, 02:10 AM   #8
Espen
Member#: 57582
2003 WRX
WRC Blue
My blobeye WRX runs just fine with 565cc injectors with just setting the "Injector Flow Scaling". I suspect "tip-in" and every fuel setting map is corrected with a factor when adjusting this setting.
Espen is offline   Reply With Quote
Old 07-08-2008, 02:18 AM   #9
Beam
Member#: 29742
2011 STI
15 S1000R
Originally Posted by Phatron View Post
Beam,
Absolutely. LC-1 in conjunction with Ecu Edit.
Thanks for the tip. no pun intended.
Old 07-08-2008, 11:28 AM   #10
testes1010
Member#: 47145
2012 Gas Saver
for tip-in changes:
original injector scalar / new injector = %
Multiply % to the original tip in table.
testes1010 is offline   Reply With Quote
Old 07-08-2008, 11:58 AM   #11
AruisDante
Member#: 122365
Ice Silver
Hmmm, some good advice. I didn't even think about tip-in changes.
Old 07-08-2008, 12:39 PM   #12
benw
Member#: 103320
1998 swapped
Forester L
In my experience, the 565cc can get away with just a scalar change and stock latencies. If you look at the JDM STIs that use "pinks" they have the same latencies as the USDM WRX 2.0L. However, the tip-in definitely needs to be adjusted with larger injectors. It may drive OK with the stock tip-in, but crisper response can be gained by tuning it, especially the low-delta areas that you spend a lot of time in.
benw is offline   Reply With Quote
Old 07-08-2008, 02:44 PM   #13
JustinS STi
Member#: 65125
05 STi
[IMG] screen shot[/IMG]
Hey, that looks familiar!
Justin (05 STi)
JustinS STi is offline   Reply With Quote
Old 07-08-2008, 08:19 PM   #14
Freon
Member#: 88322
2009 BMW 135i
I think tip in is more of a crap shoot, but I would generally reduce the values with larger injectors and work from there.
Freon is offline   Reply With Quote
How to tune for 5mt? adamlavender Newbies & FAQs 32 02-01-2009 01:03 PM
How to tune for a GM Boost Solenoid? Nuke209 Commercial ECU Reflashes 9 03-30-2007 07:14 PM
how to tune for headers/intake/intercooler w/ streetuner? anthonyrb98 Engine Management & Tuning 2 04-01-2005 10:10 AM
UTEC: How to tune for added displacement? LiquidForce Engine Management & Tuning 2 04-04-2004 01:13 PM
How to tune for intercooler upgrade? Chef_C Engine Management & Tuning 2 09-23-2003 07:07 AM
