Old 06-30-2008, 05:47 PM   #1
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Default Current draw
I'm getting 0.4 amps currents draw when the car is switched off.
What the min current draw. Also how much does aquamist draw when off.
My02 WRX sedan 5sp manaul
runner19 is offline   Reply With Quote
Old 06-30-2008, 07:41 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Normal draw should be about 35 milliamps so you have about 10 times the normal draw. Did you allow enough time for the systems to go into the sleep mode before taking the measurement? If you need to find the area that is causing the excessive draw pull fuses one at a time to see which circuit makes a difference.
Old 06-30-2008, 07:42 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you're certain it's .4A (400ma), that's too much.
Make sure your trunk light isn't on, that's about the amount it would draw. If that's not it then you have to start disconnecting things until the draw normalizes. It shouldn't be more than about 50ma give or take.
edit- one minute too slow.
Old 06-30-2008, 10:40 PM   #4
Cougar4
Member#: 53443
Winestone
I'm sure you'll beat me on the next one Mulder.
Old 07-01-2008, 09:38 AM   #5
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
trunk light is cold. I do have a aquamist 2d system thou. It it wired via relay to a ignition on trigger wire.
Old 07-02-2008, 02:47 AM   #6
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
this shouldnt be pulling any power with the key off then as the relay should be interupting power to it. You could check though by seeing if theres voltage at the controller with the key off.
I would just start pulling fuses one at a time till you find the culprit as cougar, and mulder stated.
ProdriveDreams is offline   Reply With Quote
Old 07-03-2008, 09:53 AM   #7
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
There is current draw at the pump with the ign off. key removed. bugger
Current draw on heated seats jonney_boy Newbies & FAQs 1 02-10-2007 06:29 AM
Car off current draw... freeman.matt Electrical & Lighting 7 03-18-2006 12:50 AM
Current Draw on WRX at Rest StopTech Electrical & Lighting 8 01-24-2005 10:51 PM
STi alternator current draw sti_ln Electrical & Lighting 0 11-05-2003 10:32 AM
current draw gypsymoth Electrical & Lighting 1 05-30-2003 06:22 AM
