Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 06-30-2008, 08:20 PM   #1
awd-box-turbo
Member#: 64057
08 Forester XT
33J
Default Utec Delta valet mode ????
so i have a stage 4 VF34 set up with sti pinks and i was wondering if valet mode is still functional? i tried switching to map 7 and my knock light came on... so, my question is, if you upgrade your turbo and injectors do you lose the valet mode map?
awd-box-turbo is offline   Reply With Quote
Old 07-01-2008, 01:50 PM   #2
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Map 7 is Security Mode. Map 6 is Valet mode, IIRC. In Security Mode the CEL will continuously flash.
bcblues is offline   Reply With Quote
Old 07-06-2008, 12:33 AM   #3
awd-box-turbo
Member#: 64057
08 Forester XT
33J
so does this mean that valet mode should still work with an upgraded turbo?
Old 07-06-2008, 12:59 AM   #4
Racer_X_X
Member#: 141804
'98 RSTi HTA86 AEM
'02 35R-Nürburgring Cert.
Yes it will work, read the manual, it gives a few other specifics about it.
It's a cool feature.
Racer_X_X is offline   Reply With Quote
Old 07-16-2008, 10:35 AM   #5
cwrx2001
Member#: 160860
2011 Impreza WRX STI
Satin White Pearl
I was wondering, is it safe to use the Valet mode as a daily drive ?
cwrx2001 is offline   Reply With Quote
Old 07-16-2008, 12:32 PM   #6
kamil212
Member#: 90596
2009 Scrambler
Bitches love Scramblers
So what does it do again?
I think I noticed it only allows 7-8psi of boost (meaning mechanical boost control, correct?)
kamil212 is offline   Reply With Quote
Old 07-16-2008, 01:14 PM   #7
awd-box-turbo
Member#: 64057
08 Forester XT
33J
yeah i would like to know that also... COULD YOU USE VALET MODE FOR DAILY DRIVING?
Old 07-22-2008, 02:49 AM   #8
akturbogti
Member#: 119474
05 Hummer H2
black
I wouldn't, my car won't even start when the map selector is on valet mode for some reason.
akturbogti is offline   Reply With Quote
Old 07-22-2008, 09:25 AM   #9
kamil212
Member#: 90596
2009 Scrambler
You're probably on the security mode than.
Old 07-22-2008, 12:49 PM   #10
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
In the immortal words of... well, someone, RTFM!!!!!
From the manual:
Valet mode is selected by turning the switch to Map 6. This lowers maximum boost
to 7 psi, runs limited timing and uses your Map 1 fuel map (note this is why we
recommend placing your conservative street map in Map 1). The valet will have no
fun hotrodding in your WRX!
So, this means several things. First, for valet mode to limit boost, the UTEC needs to be able to control it. Meaning if you have an MBC, this isn't going to work. Second, it runs mad retarded timing. Meaning that your BSFC will go into the ****ter. This means you'll get terrible gas miliage. Third, it uses your fuel map from map 1. Odds are pretty good this map is gonna be rich anyway, making your fuel miliage an performance even worse.
So, why, in the name of all that's holy, would you want to run valet mode all the time? It's not going to improve fuel economy, it's going to worsen it sevearly. The whole point of Valet mode is to make your car run like crap so that the Valet isn't tempted to take it for a joy ride, ala Ferris Bueler's Day Off.
If you want a low boost map for fuel economy, do it the right way. Make an economy map. That's the whole reason the UTEC gives you 5 user tunable maps to work with. Limit the boost to less than 1 BAR, tune the fuel nice and lean, and get the timing as close to MBT as you can.
AruisDante is offline   Reply With Quote
FS : Helix CBE, Utec Delta rmstires Engine/Power/Exhaust 1 06-05-2010 04:59 PM
wandering idle with valet mode [utec] santofontana Engine Management & Tuning 17 02-27-2005 11:47 AM
UTEC valet mode bluebaru wrx Engine Management & Tuning 26 09-21-2004 02:05 AM
make sure its not in valet mode bahboy20 Car Audio, Video & Security 3 08-16-2001 01:46 PM
Security System stuck in Valet Mode??? cincyRS Technical Forum Archive 2 07-21-2000 09:24 AM
