Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 06-30-2008, 09:28 PM   #1
Jasonzemos
Member#: 109993
2006 TR E3-16G'ed
Running E85!
Default Upper clutch switch Confused
My goal is a clutch switch bypass (now that I have the utec occupying the clutch switch itself, I need a bypass switch for cruise control) (If I simply close the circuit the car will think the clutch is always in and shift funny)
I have a triple prong (powered) radio shack switch.
Power || ACC || Ground
There are two wires coming from the clutch switch, I believe one is powered and one is a marked ground. I also have accessory system power and ground available obviously.
The switch itself toggles the ACC prong to ground AFAIK.
My thoughts are that its impossible to utilize the lighting feature on this switch, because there is only 1 ground prong, and I need to separate the ground for the light from the ground the ecu sees... Is there any way I can wire this switch to have it light up and not melt the ecu?
Jasonzemos is offline   Reply With Quote
Old 07-01-2008, 02:05 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
why not just reverse the switch so ground is the power source then you essentially have two seperated circuits after the power wire.
ProdriveDreams is offline   Reply With Quote
Interior Trim- Upper vents, switch bezels, vent rounds, and Wrx1234 Interior/Dressup/Audio & Security 16 05-01-2007 06:17 PM
Clutch selection confusion krzemienr Transmission (AT/MT) & Driveline 0 04-13-2007 02:50 AM
Help. 96 L - Clutch replacement - Confused. Hitokiri Transmission (AT/MT) & Driveline 6 10-19-2004 02:08 PM
Disconnecting clutch switch nathan power Normally Aspirated Powertrain 13 11-29-2000 07:40 PM
