Old 06-16-2008, 09:11 AM   #1
dtl1218
Member#: 126740
2001 Swapped 2.5 RS
Default 2002 WRX swap into 2001 RS swap question
I'm done tearing apart a wrecked 2002 WRX and I'll be starting to take apart the RS this week. I'm keeping the RS drivetrain and the wrecked WRX has a new clutch that I'd like to use. I know the WRX has a pull type clutch and the RS has a push type. Anyone know if the pull type setup can be adapted over to the RS trans so I can use the new WRX clutch? It would help me save a few dollars from having to buy a new clutch for the RS trans while doing the swap.
Thanks!
David L.
dtl1218 is offline   Reply With Quote
Old 06-16-2008, 10:34 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
simple answer
--->no<--
Old 06-16-2008, 02:39 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Couldn't he put the WRX clutch disk into his RS flywheel and pressure plate?
ciper is offline   Reply With Quote
Old 06-16-2008, 02:57 PM   #4
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
no u have to get a clutch made for your tranny
the 01 rs tranny
not the 02 wrx
only way u can you that clutch is with a 02 wrx tranny(or newer)
thisisthenewsic is offline   Reply With Quote
Old 06-16-2008, 06:37 PM   #5
dtl1218
Member#: 126740
2001 Swapped 2.5 RS
Sucks, guess I'll be clutch shopping. Thanks for the help.
David
Old 06-16-2008, 07:40 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
the 01 rs tranny
not the 02 wrx
The spline count and outer diameter is the same. Thickness when new is essentially the same. The clutch disc should be interchangeable assuming you retain the correct pressure plate and flywheel.
Do you think pull style clutches came out with the 02 WRX? If so I'd like to introduce you to the 1991 Legacy Turbo which happens to use the "02 WRX tranny(or newer)" style of clutch.
Old 06-17-2008, 07:58 AM   #7
dtl1218
Member#: 126740
2001 Swapped 2.5 RS
While we're at it, anyone have a favorite clutch for such an RS swap? I think the stock exedy wouldn't be enough.
Old 06-17-2008, 08:14 AM   #8
silentt
Member#: 119995
2004 Outback XT
Peachy
I would still use the WRX tranny. The longer gears are really nice while you're in boost, short gears + boost can get annoying.
silentt is offline   Reply With Quote
Old 06-17-2008, 10:39 AM   #9
NFJ79
Member#: 90750
2000 RS EJ207 Hybrid
2006 BMW K1200S
I have the ACT Heavy Duty Clutch kit for my swap. Dont ask me how i like it, because i am still in the swap process. But, i've heard great things about this clutch. I bought mine from www.prostreetonline.com on sale. The part number you want is SB2-HDSS. Right now, they are 10% off from prostreet.
NFJ79 is offline   Reply With Quote
Old 06-17-2008, 12:50 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
I'm using the act clutch kit SB2-HDSS on a 98 RS with an 05 STI swap. The kit has the "performance disc" and the heavy duty pressure plate. The pedal is a little firmer than stock but once adjusted properly its very easy to drive.
Old 06-17-2008, 04:36 PM   #11
dtl1218
Member#: 126740
2001 Swapped 2.5 RS
Dag,
That clutch is $475. I paid $365 for a spec stage 3 clutch a while back for a different project and thought that was expensive. I'm going to cheap out in the short run and just install the WRX tranny and its rear end. I'll keep the RS stuff for if and when I feel like swapping that over.
David
Old 06-30-2008, 11:00 PM   #12
dtl1218
Member#: 126740
2001 Swapped 2.5 RS
With fire extinguisher readied, it started on the first turn of the key. Only the airbag light is on since the seats aren't connected. I need to bleed the clutch and fasten on a few things and it should be on the road. Its been just under two weeks since tearing up the RS and I need the car now since my truck decided to mess up.
David
Old 06-30-2008, 11:07 PM   #13
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
i got act hdr4
look around on forums and ebay for clutches. could snatch it up cheap
slava from goshen is offline   Reply With Quote
Old 08-13-2008, 01:35 PM   #14
dtl1218
Member#: 126740
2001 Swapped 2.5 RS
The car has been doing well over the past few weeks, no real issues other than the clutch is now slipping so now I'm thinking over putting the RS tranny and rear back in and upgrading the clutch and maybe flywheel. Anyone know if an upgraded RS clutch can be used on a WRX flywheel? I hope so b/c I sold the RS engine three weeks ago, if not, then I guess I'll be buying a lighter flywheel as well.
Thanks,
David
Old 08-13-2008, 01:58 PM   #15
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
Hey a few things you need to know...
The rs tranny isn't really made to take the abuse of a modded turbo engine so you may begin to lose gears and blow the tranny basically. A stock weight flywheel will help save on teh trans some, but don't go with a puck style disk becuase it will be really hard on the trans.
Exedy makes some of the most reliable stuff it seems for subie and I love my stage 1 organic I have on my 98 leg. I will be using my stock flywheel and that clutch on my wrx swap in my leg. However I will be using all my legacy parts...keeping thigns with teh trans...
I'd suggest just getting an organic clutch and using the rs tranny...they seem to be just as decent at the new wrx trannies becuase they both don't like abuse or get a mfactory set and beat the piss out of it...talk to dylan at ds1 if you have any ?'s relaly nice guy and the person i got all my info from
greenspeed is offline   Reply With Quote
JDM V7 wrx wheel installed into 2001 RS airbag question scooby_snacks_imprez Interior & Exterior Modification 4 10-21-2006 02:27 PM
2002 WRX Radio in 2001 RS thetrev8588 Electrical & Lighting 1 10-19-2006 03:32 PM
2.2 swap into 2001 rs bryan2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 12 07-15-2003 02:23 PM
('93-'01) besides HP, why is 2002 WRX better than 2001 RS? Shrubba Impreza Forum 14 04-10-2001 04:10 PM
