Old 02-07-2010, 08:06 PM   #226
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Bruce, do me a favor and take a pic of the distribution block separate and also the fittings out of the block so I can look at them.
D Money is offline   Reply With Quote
Old 02-08-2010, 01:14 AM   #227
Vehicle336
Member#: 220973
Vivid racing = Agency Power.
Vehicle336 is offline   Reply With Quote
Old 02-08-2010, 07:39 AM   #228
brcewane
Member#: 63990
Flat Grey
Details can be found here:
http://www.agency-power.com/catalog/...09-p-7778.html
And here is the distribution block picture:
brcewane is offline   Reply With Quote
Old 02-08-2010, 04:16 PM   #229
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Now looking at it you could keep those rails they look ok, but i would scrap the block and get the one D has, found here. 100181
http://www.anplumbing.com/shop/index...pt=Fuel!_Block
waynoSTI is offline   Reply With Quote
Old 02-08-2010, 04:21 PM   #230
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I see it now. They have you run one feed line -8AN and two -6AN to the rails, then the other side of the rails run two -6ANs back to the block. But where is the fpr? They are having you run everything back to the block....
He can't, unless he plans on running an fpr.
Old 02-08-2010, 08:27 PM   #231
brcewane
Member#: 63990
Flat Grey
They end up actually all -6AN fittings.. for some reason the fuel feed line is an -8AN to -6AN adapter and all the lines had -6AN fittings. On the top of the distribution block you place the OEM Fuel Pressure regulator which then has the fuel return line connected to it.
Old 02-08-2010, 10:07 PM   #232
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Tim get an aeromotive FPR like i have, or go all out and get the one D has! they are both aeromotive! then run the proper lines to and from it. It will work way better and look way nicer bro! here's mine
http://www.innovativetuning.com/cata...oducts_id=1408
Old 02-08-2010, 10:35 PM   #233
VKInnovations
Member#: 229226
-10AN inlet?! That's quite big isn't it Wayne?
VKInnovations is offline   Reply With Quote
Old 02-08-2010, 10:40 PM   #234
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Ya it is but you just a -10orb to -8 or -6 reducer for whatever line your using and your good to go. 2 of these.
http://www.summitracing.com/parts/AEI-15610/
Old 02-08-2010, 10:43 PM   #235
VKInnovations
Member#: 229226
I dont even know what the heck I'll be using lol. Might just get the same FPR you have.
I know Tim will figure out what he's going to run, he always does!
Old 02-09-2010, 01:26 AM   #236
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
That's not the right reg, Wayne. lol
He would want this one:
http://www.summitracing.com/parts/AEI-13109/
and this is the one I have:
http://www.summitracing.com/parts/AEI-13159/
Bruce, think this one out. I really think you should ditch that entire setup and start fresh. That's just my opinion of course.
Old 02-09-2010, 09:01 AM   #237
brcewane
Member#: 63990
Flat Grey
Ok..Ok.... I am pretty much sold
I think what I am going to do is ditch the distribution block and do the following:
- Aeromotive 13159 FPR (http://www.summitracing.com/parts/AEI-13159/)
- EARLs Distribution block 100181 (http://www.anplumbing.com/shop/index...pt=Fuel!_Block)
- Keep my rails because I like how they look
D... I can't seem to find any dimension information about the FPR.. I just want to make sure that it will fit where I want to mount it. Any chance you could get me some HxWxD measurements off of your FPR?
For the FPR will I need:
- 3 strait -6AN to -6AN Union-Male A.N. TO A.N. Adapters (AT981506)
And for the distribution block I guess I would need:
- 2 x -6AN to -6AN Union-Male A.N. TO A.N. Adapters (AT981506)
- 1 x -6AN to 3/8 Straight, Pipe Thread To A.N. Adapter (AT981666)
I just want to make sure I have things straight in my head
Old 02-09-2010, 01:36 PM   #238
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
D I was showing Tim the one I have, I couldn't find the -6 one on that sight last night! Give me a little credit homie, I'm not a fuel system guru like you but I have been listening to everything you've been telling me! Lol
D you tell him all that he needs I don't want to confuse the situation anymore.
Old 02-09-2010, 01:45 PM   #239
White out
Member#: 46277
** LP640
Viper GTS
As far as your power steering set up, don't use the magnus for a mounting point or brace. It is a very weak piece and will likely end up with stress cracks in that area.
I had some issues with mine cracking from a mounting point for a fuel rail block. It's a very brittle piece.
Nick
White out is offline   Reply With Quote
Old 02-09-2010, 04:38 PM   #240
brcewane
Member#: 63990
Flat Grey
Nick
Yeah, I'm making sure to not mount anything on it
The Power Steering reservoir will be bolted to the block
Old 02-09-2010, 09:25 PM   #241
brcewane
Member#: 63990
Flat Grey
I think everything I have is right, I just didn't know if I needed the strait AN fittings, or if I needed the O ring fittings
But I have some time to figure it all out
Old 02-09-2010, 09:27 PM   #242
brcewane
Member#: 63990
Flat Grey
Say hello to my Home Depot intercooler piping mock-up kit!!! A sack full of 45/60/90 degree bends and a bunch of 2 inch PVC piping. The outer diameter of the PVC piping is only 1/8 inch smaller than the 2.5 inch stainless pipes. So it should make for a pretty accurate representation.
I'll be able to cut and piece the piping sections together like LEGO. I'll then use some PVC pipe glue to hold them together and then take them to a shop to make me some stainless pipes with the same bends... or at least that is the plan
Old 02-09-2010, 09:33 PM   #243
VKInnovations
Member#: 229226
full carbon piping?
Old 02-09-2010, 09:40 PM   #244
brcewane
Member#: 63990
Flat Grey
Originally Posted by VKInnovations View Post
full carbon piping?
Hey.. if you want to do it.. count me in for the guinea pig
Old 02-09-2010, 09:46 PM   #245
VKInnovations
Member#: 229226
haha... been thinking about it for a while, but dont know if I can make pipes, that would hold 60psi.
Old 02-09-2010, 09:50 PM   #246
brcewane
Member#: 63990
Flat Grey
You could always do CF wrapped aluminum pipes... It would give the aluminum pipes more strength and still be light.
Old 02-09-2010, 09:53 PM   #247
VKInnovations
Member#: 229226
we'll talk
Old 02-10-2010, 09:24 AM   #248
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I can't get to my car for about 2 weeks, since I will be on vacation. The demensions should be online somewhere, or use my pics for a reference in sizing.
Those fittings you have are wrong. You can't run a -6AN to -6AN male union. You need what is called a ORB fitting (o-ring boss) which has a male -AN flare on one end, and -6AN orb fitting with o-ring on the other end.
Pics for reference:
-6AN to -6AN make union
-6AN to -6AN orb
See the difference? The theads are the same, but the opening is much larger! This will help your system not be restrictive.
You need the following:
www.anpluming.com/shop
FPR: **-6AN to -6AN orb**
(3) 985006
Distribution block: **3/8npt to -8AN & -6AN to -6AN orb**
(2) 985006
(1) 981608
NOTE: The earls block actually comes with two -6AN to -6AN male unions with an o-ring, however these will be restrictive due to the opening. I highly suggest you replace them and sell those fittings it comes with.
http://www.summitracing.com/parts/EAR-100181ERL/
No, wayne you're doing good man! I had to learn from people also when I put my system together.
Old 02-10-2010, 03:17 PM   #249
brcewane
Member#: 63990
Flat Grey
Cool.. Thanks D!!
Old 02-10-2010, 03:28 PM   #250
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Yup, that should help. I can help you with the rest of the system too. If you get stuck, just pm me or I can give you my number.
Pics Of the Bugeye before it goes under the knife. smileyou Member's Car Gallery 21 12-05-2008 05:44 PM
Going under the knife tomorrow morning. First reply gets the ruckus kbcr3 Off-Topic 81 01-18-2008 05:06 PM
Mastro Monster goes under the knife... Opie South East Region Forum 48 01-24-2005 08:43 PM
OT: The Mustang goes under the knife (pics) Patrick Olsen New England Impreza Club Forum -- NESIC 8 05-16-2001 02:33 PM
