Old 02-10-2010, 04:08 PM   #251
brcewane
Member#: 63990
Flat Grey
Originally Posted by D Money View Post
Yup, that should help. I can help you with the rest of the system too. If you get stuck, just pm me or I can give you my number.
I take it that the **3/8npt to -8AN ** for the distribution block is if I am running an -8AN fuel feed correct?
I'm going to be running a -6AN fuel feed from my filter so logic would tell me that I would be running a 3/8npt to -6AN
brcewane is offline   Reply With Quote
Old 02-10-2010, 04:41 PM   #252
ugetworked311
Member#: 39792
in for updates.
ugetworked311 is offline   Reply With Quote
Old 02-10-2010, 04:43 PM   #253
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Correct. I thought you would be running -8an.
This is the correct part number then.
981666
D Money is offline   Reply With Quote
Old 02-10-2010, 09:46 PM   #254
brcewane
Member#: 63990
Flat Grey
I think the raw silver aluminum version of this 70mm throttle body will be finding its way to my car too
Direct bolt on that accepts all stock sensors. I removed my cruise control, so I don't need the second cable.
Old 02-10-2010, 09:51 PM   #255
brcewane
Member#: 63990
Flat Grey
Oh and the Polished Agency Power Turbo Inlet pipe and Forge coolant tank have just been shipped.. so hopefully that bling gets here soon
Old 02-10-2010, 11:02 PM   #256
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
wait, they make that 70mm tb in polished? And it requires no modification to work? I think that's a must for me!
That's the ebay one right?
Old 02-10-2010, 11:20 PM   #257
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
I wish i had DBC, there are so many options for you guys. That would look sick on your car Tim.
D aren't you running the cozzie mani? You would still need to make a plate for this i think? Would look great on your car.
waynoSTI is offline   Reply With Quote
Old 02-11-2010, 07:35 AM   #258
brcewane
Member#: 63990
Flat Grey
Voila:
http://nozzs.com/index.php?main_page...products_id=18
Old 02-11-2010, 07:35 AM   #259
brcewane
Member#: 63990
Flat Grey
Doh.. double post
Old 02-11-2010, 10:21 AM   #260
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
scby rex has it and I think he said he had to do some type of modification to make it work.
Old 02-11-2010, 11:14 AM   #261
brcewane
Member#: 63990
Flat Grey
Does scby rex have a thread with any details?... I'm curious on what had to be done.
Old 02-20-2010, 10:37 AM   #262
brcewane
Member#: 63990
Flat Grey
FYI for those interested
Originally Posted by scby rex
You have to port the manifold to match the 70mm butterfly, I also had to shave the back of the alt for a little more room for the temp sensor(reversed manifolds only).
Then I have to shave a little off the cable pully so it stopped hitting the manifold before wot. Also had to open up the hole for the cable end to fit in the pully. Ive told the manufacturer about it and the said they were going to try to fix thos problems.
You have to be careful while porting the manifold because you wont have much material left between the opening and the opening for the iac valve. This all also means you cant use the oem gasket, I used gasket sealer and it works fine.
I think I am going to try this throttle body out since most of the issues are for reversed manifolds and the stock manifold.
Old 02-20-2010, 10:44 AM   #263
brcewane
Member#: 63990
Flat Grey
After getting back from one week in Barcelona for work, I found a little bit of engine bay accessory bling
It should go well with the Forge reservoir tank that is on the way. It fits right over top of the OEM cap and secures with a set screw. Just like the Project Mu caps I have.
Old 02-22-2010, 07:30 AM   #264
brcewane
Member#: 63990
Flat Grey
So which one should I go with BLUE or SILVER.... The blue would go with some of the other anodized bits in the engine bay (rails, project mu caps, oil cap) but the silver would stick with the polished theme.
I'm leaning towards silver because I think it will be less of a visual distraction.
Old 02-22-2010, 11:21 AM   #265
DB360
Member#: 231175
silver is what i would get if i were you.
DB360 is offline   Reply With Quote
Old 02-22-2010, 01:49 PM   #266
subiVeritas
Member#: 179349
02 2004 WRB STI
09 ZX6R
i say silver too even tho i would personally go blue
subiVeritas is offline   Reply With Quote
Old 02-22-2010, 04:01 PM   #267
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
is the tb OD bigger? In other words, do you need a bigger coupler and piping to fit over it? Or just the ID is bigger?
Old 02-22-2010, 06:38 PM   #268
brcewane
Member#: 63990
Flat Grey
I'm not sure, I never thought to ask them about it.... but I am really on the fence if I want to go this route. I measured my Magnus butterfly opening and it is the same as stock. I would have to bore out the Magnus opening to match the 70mm butterfly of the TB. I'm worried about messing up the opening for the IAC valve at the top.
Here were the latest emails from them:
Are you upgrading an intake manifold or use the stock intake manifold? Does this going to be on GDA or GDB?
There are some modification required for properly TB operation. TB bolts on to stock bolt pattern on the intake manifold but since the butterfly is bigger than the stock, you will need to bore the inside of the inlet of the stock intake manifold to allow full open. All sensors will fit onto the tb. ( TPS, map) For the throttle body cable, you can use the stock cable.
have a good day and thank you for your interest.
Only blue TB is in stock and ready to ship. However, if you like to get it in silver, please allow 7-14 days to make it.
have a good day.
I also found this one from Godspeed:
http://www.godspeedproject.com/store...oducts_id=1053
You can see from theirs just how thin that section between the butterfly opening and iac is:
I'm thinking I might end up cleaning up the stock TB and paint it Gunmetal to match my Power steering pump and other accessories. I'm going to try and delete the second pulley on the stock TB as well.
Old 02-22-2010, 06:40 PM   #269
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
A 2.75 coupler will fit over it, thats what Im using. You can see that it streaches the coupler slightly.
Atleast they told you what I told them. They didnt know about their fitment until I told them about it.
scby rex is offline   Reply With Quote
Old 02-22-2010, 10:56 PM   #270
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I will sell you my chromed, ported tb and ill buy that 70mm one.
scby rex, so a 2.75 will fit over it? That's what size piping I am running.
Old 02-25-2010, 05:21 PM   #271
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
I don't see the point going through all this trouble for a few 3-5mm! If you're going to do it then at least get an 80mm TB and run 2.75" or 3" pipe on the cold side.
If you go ahead and do it then i would do the silver.
Old 02-25-2010, 05:53 PM   #272
silversuby2
Member#: 219518
02 impreza wrx
blue is too flashy imo. silver!
silversuby2 is offline   Reply With Quote
Old 02-27-2010, 05:05 PM   #273
brcewane
Member#: 63990
Flat Grey
Since I'm back from good old Spain, I was able to pick up a bunch of new bolts, washers and gaskets from Robbie and started mocking up my new intercooler piping. I wasn't able to finish the passenger side because of that damn ABS unit that will have to be removed before I can finish
I also mocked up where the power steering reservoir, BOV and coolant reservoir go so that I could get a look at how it will all come together. My polished turbo inlet and forge coolant reservoir have finally cleared Canadian customs so they should be here any day now.
And now for the pictures.. Picture the 2.5" pipes all nice and polished
Old 02-27-2010, 05:14 PM   #274
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
hmm... very innovative way of doing things...
Looking good so far
jigga is offline   Reply With Quote
Old 02-28-2010, 07:58 AM   #275
brcewane
Member#: 63990
Flat Grey
I think I'll likely re-do the part coming from the turbo and heading towards the drivers side with the BOV on it.
I did that section first and then I started working on the passenger side. I'll shape it more like the section that goes over the turbo to make it look more symmetrical.
Gotta love PVC.. I can just cut a few pieces and stick it together like LEGO
Pics Of the Bugeye before it goes under the knife. smileyou Member's Car Gallery 21 12-05-2008 05:44 PM
Going under the knife tomorrow morning. First reply gets the ruckus kbcr3 Off-Topic 81 01-18-2008 05:06 PM
Mastro Monster goes under the knife... Opie South East Region Forum 48 01-24-2005 08:43 PM
OT: The Mustang goes under the knife (pics) Patrick Olsen New England Impreza Club Forum -- NESIC 8 05-16-2001 02:33 PM
