Old 09-04-2012, 10:54 PM   #726
brcewane
Member#: 63990
Flat Grey
I made lots of progress on the manifold tonight... One more evening should have it stripped down to the bare bones. There will be some aluminum welding patch work to be done before it goes to polish.
We're going to test fit everything and make any modifications to use the DBC throttle body before I get it out to Sami for polishing.
If we need to make them shorter for hood clearance we should be able to chop the runners and weld them back together. This manifold will replace my TGVs.
I'll try and post some progress pictures tomorrow night once I'm done.
brcewane is offline   Reply With Quote
Old 09-05-2012, 01:35 AM   #727
Dr. Balog
Member#: 276104
Good luck with the rebuild. Sucks to hear that a true grease monkeys hard work was just molested like that. Ill be looking forward to the rebuild.
Dr. Balog is offline   Reply With Quote
Old 09-05-2012, 09:56 AM   #728
brcewane
Member#: 63990
Flat Grey
I know.. I feel so violated
Old 09-05-2012, 10:52 PM   #729
brcewane
Member#: 63990
Flat Grey
I was able to finish off the 2.5 rs intake manifold tonight. I'm too tired to post up the pictures, but I'll try and get them up tomorrow.
Cleared everything off the manifold except for the couple vacuum lines that I'll need for my brake booster, fuel pressure regulator etc. This should look pretty cool polished up and replacing my TGVs.
I'll also have to drill and tap some new holes for the throttle body. Since I have a 73mm throttle body now, I'll bust out the die grinder and open up the inlet to match
There are 4 holes to weld up and smooth out. I've probably spent 5 hours on it so far
Old 09-06-2012, 08:26 AM   #730
brcewane
Member#: 63990
Flat Grey
OK... now for the pictures.
This is what the 2.5 RS JDM manifold looks like with all the junk attached to it
After clearing off all the bolt on pieces you end up with something that looks like the following
After two and a half hours of cutting and grinding you end up with something that looks like the pictures below. You can see where I started grinding off the lower runs that end up going to a tube that sticks up right in the center of where the inlet is.
After another two and a half hours the following night I ended up getting it all finished. There are a couple holes that will be patched/welded and then ground down smooth. Once all the test fitting is done it will go out to the polisher
I left the two threaded tabs on the bottom because they line up with where the throttle body cable will need to run. I figure these will make good mounting points for a bracket holding the cable on the bottom of the manifold.
Old 09-06-2012, 08:46 AM   #731
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Good job bro! She's going to look sick once Sami get his hands on it
waynoSTI is offline   Reply With Quote
Old 09-06-2012, 02:16 PM   #732
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
I just saw that post about the stuff bein stolen... That's terrible . Good luck with the rebuild!
StealthWRX is offline   Reply With Quote
Old 09-07-2012, 09:18 PM   #733
brcewane
Member#: 63990
Flat Grey
Ordered the same oil filler and cap as Wayne today and some 10mm dress up bolts
http://www.outfrontmotorsports.com/oil_filler.htm
Old 09-08-2012, 11:04 AM   #734
brcewane
Member#: 63990
Flat Grey
I had forgot to ask Ultimate Racing.. does anyone know if the T3/T40E is water cooled? Or is it oil cooled only?
I'll give them a call on Monday to make sure, but I was curious if anyone knew off hand. It will help me plan out my engine bay on whether or not I need the top coolant reservoir
Old 09-09-2012, 10:26 AM   #735
brcewane
Member#: 63990
Flat Grey
So it looks like my DBC Throttle body isn't going to fit/work without a bit more fabrication on the 2.5 RS intake manifold. For one the bolt pattern doesn't match up, and they aren't the same size bolts either.
Plus if you look at the back of the WRX throttle body you'll see that there is a little channel that matches up with the intake manifold to let air up into the top sensor. Of course this isn't there on the RS manifold.
First I posted in Cribbie's thread to see if he had an adapter plate, because it looks like he ran into the same scenario. Then I realized I could just cut the mounting area off of a junk stock WRX intake manifold and weld it onto this new 2.5 RS one.
Looking to pick up a spare WRX intake manifold tomorrow and do the cutting tomorrow night.
Old 09-09-2012, 01:27 PM   #736
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
water jetting one would be a better option I think. Theres a bunch of crap behind the wrx opening for the iacv and getting that all in the 2.5i manifold would be a huge pita.
scby rex is offline   Reply With Quote
Old 09-12-2012, 10:59 PM   #737
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
I can't remember your setup and I'm too tired to search but somebody mentioned that the 2.5 manifold isn't the same as the wrx 2.0 heads. You know if there is any truth to this?
...and I don't know why I'm not sub'd already...sooooo yeah subscribed
King of Poop is offline   Reply With Quote
Old 09-13-2012, 12:03 AM   #738
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Call up IAG bro and see if they can make you a spacer on there CNC machine.
It would be cheaper and a better option.
Old 09-13-2012, 08:37 AM   #739
brcewane
Member#: 63990
Flat Grey
Talked to Frank and we're going to make something out of 1/2" aluminum
Old 09-13-2012, 12:37 PM   #740
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Awesome! That's good news bro.
Old 09-14-2012, 07:19 AM   #741
brcewane
Member#: 63990
Flat Grey
Dropped off the UR turbo stuff yesterday.. We're going to fix up all the flow, flange and welding issues... Yikes!
Old 09-20-2012, 04:32 PM   #742
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
How you making out bro? any good news
Old 09-20-2012, 06:01 PM   #743
brcewane
Member#: 63990
Flat Grey
Everything has been sourced, planned and assembly started happening this afternoon
Old 10-08-2012, 09:50 AM   #744
brcewane
Member#: 63990
Flat Grey
Intake Manifold has been now been fitted, throttle body mounted and alternator flipped.
Had to hole out the feet of the Intake manifold to match the spread of the STi block and WRX heads.
Old 10-12-2012, 07:54 PM   #745
brcewane
Member#: 63990
Flat Grey
Heading to the shop tomorrow morning to check-out the progress so far. I'll bring the camera with me
Old 10-14-2012, 12:05 AM   #746
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
F@@K!! sorry to hear about that happened! Hope everything turns out good!
YZ86 is offline   Reply With Quote
Old 10-14-2012, 08:41 AM   #747
brcewane
Member#: 63990
Flat Grey
Paid a visit to the shop yesterday. Things are coming along. Need to get some fuel rail mounts machined and run the fuel lines and we should be almost ready to go.
Ended up going with 2" intercooler piping
Old 10-14-2012, 09:29 AM   #748
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Where's the pics bro?
Old 10-14-2012, 09:32 AM   #749
brcewane
Member#: 63990
Flat Grey
Franks been taking some progress pics that I'll post up soon.
Old 11-04-2012, 07:47 AM   #750
brcewane
Member#: 63990
Flat Grey
Getting closer to getting the car back.. hopefully this week
Pics Of the Bugeye before it goes under the knife. smileyou Member's Car Gallery 21 12-05-2008 05:44 PM
Going under the knife tomorrow morning. First reply gets the ruckus kbcr3 Off-Topic 81 01-18-2008 05:06 PM
Mastro Monster goes under the knife... Opie South East Region Forum 48 01-24-2005 08:43 PM
OT: The Mustang goes under the knife (pics) Patrick Olsen New England Impreza Club Forum -- NESIC 8 05-16-2001 02:33 PM
