Welcome to the North American Subaru Impreza Owners Club Tuesday September 16, 2014
Old 01-09-2010, 11:52 AM   #176
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Looking good Tim! Can't wait to see it finished!
waynoSTI is offline   Reply With Quote
Old 01-09-2010, 12:27 PM   #177
SubaruWrxSTR
Member#: 199039
11 Sti on E85
15 wrx CVT
nice bugeye
SubaruWrxSTR is offline   Reply With Quote
Old 01-09-2010, 12:27 PM   #178
minhha2006
Member#: 154914
2005 WRX
UGM
Originally Posted by brcewane View Post
So Friday I finalized my order with Jerry at Deadbolt Enterprises http://www.boostplanet.com on my new ZILLA TD06H-20G. I decided to go this way instead of sending my Deadbolt 16G back to be massaged into this turbo. Downtime, shipping and scheduling of the build was just going to get in the way.
So I'll end up selling my 16G and Sti Pinks as a package once the new stuff is on.
After talking to a bunch of turbo places everyone said that the TD06-20G will be the best turbo for my setup if I am planning on running pump gas. All the other turbos that I was looking at really bring extra gain when running meth or race gas. Everyone said it isn't worth the extra cost if I wouldn't be running these. So I am quite happy with my decision.
Turbo should be shipped out 2nd day air next week. Here is what you get with Deadbolt's Water/Oil cooled ZILLA TD06H-20G:
- Black Xtreme(TM) coating-turbine housing
- Grey Ceramic coating-compressor housing
- Monster Port(TM)
- Metal coolant supply lines
- Coolant supply banjo bolts
- Coolant supply banjo seals
- Oil return line with new gasket and bolts
- Stainless steel downpipe studs
And.. FREE REBUILDS FOR LIFE
Stay tuned... as soon as this guy arrives there will be lots of pictures... So far the plan is that the car will undergo its build in 2 weeks.. pending shop availablily
Plus... as a sneak peak.. there are current plans for JUN style hood modifications... both the vent at the front and the raised vent at the rear Just working through the plans for this now.
I wanted to check them out bc you gave them such a great review so far, but I think you should check out their website again brcewane...
Is he an employee there or was the website hijacked?
minhha2006 is offline   Reply With Quote
Old 01-09-2010, 12:57 PM   #179
brcewane
Member#: 63990
Flat Grey
I think the website was hijacked
brcewane is offline   Reply With Quote
Old 01-09-2010, 12:59 PM   #180
minhha2006
Member#: 154914
2005 WRX
UGM
oh good
Now you can tell them and maybe you'll get a bonus or something!
Hopefully I will be fixed soon, I want to look through their inventory.
Old 01-09-2010, 04:48 PM   #181
brcewane
Member#: 63990
Flat Grey
The fuel filter/lines/an fittings came in.. Man that fuel filter is small
Then I decided to take apart the spare alternator so that I could paint up the casing. I'm glad I had this one as a spare because I destroyed it LOL.. everything was seized so I ended up drilling out some of the screws. It took me all afternoon to get this thing apart. I had the freaking impact gun on the pulley nut for what seemed like forever.. I also hammered out the bushing that is used for the AC compressor to connect to it.
I think I will be taking my existing alternator to an alternator build shop and have them switch the casing once I have it painted so that I don't screw it up
Started with this...
Ended up with this:
And will be painting the casing with gloss silver and the band on the outside of the wrapped wires with the black. Much like Neil did with his build.
Old 01-09-2010, 05:25 PM   #182
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
you should have it polished
All4bSpinnin is offline   Reply With Quote
Old 01-09-2010, 05:39 PM   #183
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
+1! Tim I'm polishing mine, LMK if your interested, I'm going in a few weeks when my other parts come in! we can get a better deal if we go together!
Old 01-09-2010, 06:05 PM   #184
brcewane
Member#: 63990
Flat Grey
Ok.. let me know when you are going and what kind of deal we can get.
If I'm getting them polished I'd be looking to do the following:
- Alternator
- Turbo heat shield
- Downpipe heat shield
- Throttle body housing
- APS BOV
- Throttle cable bracket
- valve covers
I'm going to be heading to Fastenal on the way to work one of these days to either pick up stainless steel or nickel plated hardware to replace the stock stuff. Let me know if you want me to pick you up some as well.
Old 01-09-2010, 06:36 PM   #185
brcewane
Member#: 63990
Flat Grey
I just picked these up for some polishing as well
Old 01-09-2010, 06:47 PM   #186
DB360
Member#: 231175
i was going to try and take my alternator out and make it look better then the old nasty look its got going on. i just did my intake manifold and was going to dress up everything to look better. if you could pm me or if someone could on how to do this that would be great. and what paint to use. i want to do the ac pump too as its looking ugggggly but havnt seen tooo many people do that. thanks for the inspiration man.
DB360 is offline   Reply With Quote
Old 01-09-2010, 06:48 PM   #187
DB360
Member#: 231175
oh and how do i go about dressing up the throttle body and the springs that are attached to it? i just have been staring at it wondering what i was going to do with it.....
Old 01-09-2010, 06:54 PM   #188
brcewane
Member#: 63990
Flat Grey
The springs are tricky.. I think the best you can do is clean them up with a small wire brush attachment on your dremel.. I think D Money couldn't figure out what to do there either.
If you paint them they will be sure to flake
Old 01-09-2010, 06:58 PM   #189
DB360
Member#: 231175
see thats why im just stuck on what to do. i was going to paint the throttle body black but then you will see the springs and what not and it will look ugly...hmmmmm. thanks man. you are doing a lot of things that i have wanted to do for a long time. very helpful man.
i was going to ask you, what are you going to do about the two connections for the intake manifold that are still sitting down there??? this is the only reason i havnt done the fuse box delete just yet.
Old 01-09-2010, 07:13 PM   #190
Noeladams
Member#: 121517
2003 WRB WRX
& WHT 93L
looking good on this project! always liked the car!
Noeladams is offline   Reply With Quote
Old 01-09-2010, 07:35 PM   #191
brcewane
Member#: 63990
Flat Grey
Are you talking about the harness plugs??? Not sure yet, I might extend the wires and hide them
Old 01-09-2010, 08:53 PM   #192
DB360
Member#: 231175
Ya, just curious how that was going to pan out.
Old 01-10-2010, 08:17 PM   #193
VKInnovations
Member#: 229226
Batmobile FTW!!!!! Cant wait to work on those brcewane custom made panels!!
VKInnovations is offline   Reply With Quote
Old 01-10-2010, 10:12 PM   #194
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
This is what they look like polished Tim! They are going to look sick on your car with the magnus! I'm really anxious to see our panels!
Old 01-10-2010, 10:26 PM   #195
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
cool project
kennyvb is offline   Reply With Quote
Old 01-11-2010, 09:33 AM   #196
brcewane
Member#: 63990
Flat Grey
Hopefully I can start to mock-up the panels in cardboard tonight.. I have attempted to draw the lines in a somewhat perspective view. I needed to get the AC lines out of the way so that I could start to make my templates. Now that I ripped them out yesterday, we should be good to go
The idea is providing panels that will look smooth and cover up the nastiness of the battery tray, the holes etc. While also providing "channels" for hiding the wiring harness with the least amount of wire extension and tucking. This should keep the margin of error of a wiring mishap down but still clean up the engine bay. The goal is to have each side of the engine bay have a one piece panel that will cover both the bottom and side for a cleaner look that two panels for each side.
The idea is that the bolts for securing it to the fender wall will be counter sunk and covered over. They will use existing holes in the fender and then washers and bolts will be attached from the outside.
I am going to be using that little plastic box for a distribution block of the Positive battery terminal where it will connect to the 4gauge wire going back to the battery in the trunk. It will all be hidden under the panels. it will pop up into the plastic box through the circle in the battery tray.
Keeping the panels up on top of the battery tray should provide clearance for wiring to run underneath it.
At least, that is the plan
Old 01-11-2010, 10:02 PM   #197
brcewane
Member#: 63990
Flat Grey
I did a little bit of mock-up in cardboard tonight and quickly realized it wasn't going to give me the smooth lines that I am after.
So I'll likely be switching to creating a frame and stretching polyester felt over it and hitting it up with some fiberglass.... then the usual of sand.. sand.. sand
I'll likely join it up with some ABS plastic sheets for where I need the straight flat panels.
Old 01-15-2010, 09:27 PM   #198
brcewane
Member#: 63990
Flat Grey
I'm thinking about having a new mount fabricated for the BOV and get a new pipe bent for where the old BOV outlet is. It just looks really weird mounted to the spot where the existing flange is and I would like to move it to the new spot. The idea would be a flange with some bolts welded into it so I could just secure it with a couple of nuts.
Wanting to have it all done in stainless steel.
Firewall is already starting to look better with all that AC crap gone off of there. Now that those hoses are gone there is room for me to mount the fuel distribution block up on top of the pitch mount bracket.
I also temporarily stuck the emblem where it will be going. I'll make a nice little surround covered in Carbon fiber to mount to this spot. I figured I would stick it there to see what it looked like.
I'm hoping to have a bunch of time this weekend to try and get some more done.
Old 01-17-2010, 09:16 AM   #199
brcewane
Member#: 63990
Flat Grey
The carnage continues
Man there is a lot of crap attached to that intake manifold!! Since I am going to be putting the coolant reservoir where the AC compressor was before, I took out the hard line going over to that area... Crappy thing was that when I removed it the coolant system decided to create a siphon and tried to purge itself!!
So I had to clamp off the hose with a vice grip.. it was like a scene from ER where I had a bleeder and I was looking for a clamp and suction
Today I'm going to drain the coolant system so that I can remove the fans. I'll be matching up my mishimoto rad with their slimline fans and shroud. Lots of gazing at the engine bay right now devising my plan of how to simplify the mess of hoses and wires
Old 01-17-2010, 12:09 PM   #200
DB360
Member#: 231175
lookin good so far. lots of hoses and wires man. looks like you got a ton of replacing to do. but it still looks ten times better already then mine. i have just the intake mani off and painted, i wanted to make the wire harness smaller somehow and not so noticable.
Pics Of the Bugeye before it goes under the knife. smileyou Member's Car Gallery 21 12-05-2008 05:44 PM
Going under the knife tomorrow morning. First reply gets the ruckus kbcr3 Off-Topic 81 01-18-2008 05:06 PM
Mastro Monster goes under the knife... Opie South East Region Forum 48 01-24-2005 08:43 PM
OT: The Mustang goes under the knife (pics) Patrick Olsen New England Impreza Club Forum -- NESIC 8 05-16-2001 02:33 PM
