Old 07-01-2008, 06:24 AM   #1
hiroaki
Member#: 133543
Chapter/Region: HIIC
2004 Wrx
Java Black Pearl
Default HID problem
I recently installed a set of Riken HIDs on my 04 wrx. The passenger light flickers then shuts off. I did cut and splice, two wires from the silver harness mounted on the back of the headlight. I changed the connectors twice on the sliced harness. As soon I change the connectors it lights up. Then when I mount the ballast and turn the car on, the light flickers and turns off again. On the side note my drive side hids still work perfectly fine. Please help me out thanks.
hiroaki is offline   Reply With Quote
Old 07-01-2008, 06:41 AM   #2
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Originally Posted by hiroaki View Post
I recently installed a set of Riken HIDs on my 04 wrx. The passenger light flickers then shuts off. I did cut and slice, two wires from the silver harness mounted on the back of the headlight. I changed the connectors twice on the sliced harness. As soon I change the connectors it lights up. Then when I mount the ballast and turn the car on, the light flickers and turns off again. On the side note my drive side hids still work perfectly fine. Please help me out thanks.
Not sure exactly what you mean by 'cut and slice', (perhaps you meant 'cut and splice') but double-check to make sure your connections are perfect.
Aftermarket HID systems are usually all the same:
Original headlight harness/plug--->aftermarket ballast-->aftermarket igniter-->aftermarket HID bulb
If you're still having problems, narrow it down to find which component in the system is faulty. Since you said that your driver side still works fine, swap each component to the passenger side, one-by-one starting with the ballast.
That should allow you to see which component of the passenger side system is bad.
lennyTR is offline   Reply With Quote
Old 07-01-2008, 11:29 AM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
this is a very common problem. two things
either the ballast is bad (not uncommon with aftermarket hids)
or you need to connect the ballasts direct to the battery with a relay. ballasts draw a much larger amperage load when they start up. usually the stock wiring cant handle it.
jdubya301 is offline   Reply With Quote
Old 07-01-2008, 06:11 PM   #4
hiroaki
Member#: 133543
2004 Wrx
Java Black Pearl
thanks guys. everything fine. just a loose connection
more hid problems fuzzy logik Electrical & Lighting 14 05-17-2003 12:02 AM
Hanabi HID problems Qbushido Electrical & Lighting 1 02-05-2003 03:03 AM
HID problem bentshoe Interior & Exterior Modification 33 01-06-2003 11:27 AM
hid problems m3eater Tri-State Area Forum 15 08-05-2002 06:09 PM
HID problem Turbotegra Interior & Exterior Modification 10 02-02-2002 04:38 AM
