Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-01-2008, 08:28 AM   #1
mvcsk8r
Member#: 182483
05 Saabaru 92X HYB
Default 2.0 to 2.5 hybrid build question
Ok I have been reading to the point where my eyes hurt. I have an 05 wrx and spun a bearing. I just bought an EJ257 shorth block. I was I am replacing the oil pump, catless uppipe, catles down, and thats about it. ( side note, anyone selling a decently priced DP?) This is a daily drive but a little extra HP is always nice since I have it torn apart anyway.
My question is this.
I spun a rod bearing so I am having the 2.0L head cleaned, should I have the machine shop do anything else, I have head some mention of valve jobs but not sure what angle to go with or what diffeence it really going to make with out a STI cam. Or with it for that matter. Is porting and polishing it really worth it.
Also I was planning on flashing a stage 1 map, does anyone recommend a map to use? I am on a budget and 500 bucks is a bit much to get it tuned at the local speed shop, but then again I don't want detonation so would a stage 1 map be suffice?
Any and all help is welcome thank you.
mvcsk8r is offline   Reply With Quote
Old 07-01-2008, 08:47 AM   #2
mvcsk8r
Member#: 182483
05 Saabaru 92X HYB
O and sti injectors, are they worth it?
Old 07-27-2014, 07:32 PM   #3
4WDftw
Member#: 390082
I know it's an old post but I'm looking into doing a hybrid build too and have the same question.
4WDftw is offline   Reply With Quote
Old 07-27-2014, 08:30 PM   #4
worker0813
Member#: 346387
2003 WRX
you really should look into having the heads chambered using a cnc program so that all edges are gone and all cylinders are exact. The overlap can cause hot spots that will ignite the fuel before the spark has a chance to do so.
worker0813 is offline   Reply With Quote
2.0 to 2.5 conversion.. quick question rapturem3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 07-17-2009 01:35 PM
2.0 to 2.5 swap questions own3db Subaru Conversions 15 06-06-2009 12:38 AM
Yet another 2.0 to 2.5 sti block ? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 12-22-2003 03:24 PM
2.0 to 2.5 block swap, what's the ideal Compression ratio? 516_WRX_V2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-25-2003 12:44 AM
Forester 2.0 to 2.5 engine swap???help Breen Subaru Conversions 14 10-15-2003 10:01 PM
