Old 07-01-2008, 01:32 PM   #1
piratekiller
Member#: 128262
2002 WRX wagon
Default Head Gasket
whats better OEM or aftermarket head gasket?
piratekiller is offline   Reply With Quote
Old 07-01-2008, 01:36 PM   #2
94'325is
Member#: 122315
2003 WRX
Depends on what kind of block/heads. Also what are your plans for the motor?
94'325is is offline   Reply With Quote
Old 07-01-2008, 02:25 PM   #3
piratekiller
Member#: 128262
2002 WRX wagon
I am not going to go to crazy. I bought a new EJ20 short block, I will eventually finish off the exauhst (I have up and down pipes). I am mostly going to use to car as a daily driver with the occasinal track day.
Old 07-01-2008, 02:43 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Which heads? Whats the target CR?
Old 07-01-2008, 03:26 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Stock HG work well went prepped and torqued correctly. I wouldn't recommend custom HG's to change CR if that's what you are planning, there are better ways
Old 07-01-2008, 03:30 PM   #6
piratekiller
Member#: 128262
2002 WRX wagon
OEM heads and OEM CR
Old 07-01-2008, 06:52 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
I vote OEM. I know that at least on the 2.5 NA DOHC and SOHC the gaskets are MLS which are verygood.
Old 07-02-2008, 08:52 AM   #8
piratekiller
Member#: 128262
2002 WRX wagon
OEM it is thanks.
Old 07-02-2008, 11:20 PM   #9
25rsti
Member#: 166324
what about for a sti s/b with built wrx heads? i dont know what i would want for a compression ratio because everyone one says different stuff about both high and low. but my best bet it to stay low and safe
Old 07-02-2008, 11:24 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
The stock head gaskets are MLS and really good. I do a lot of work on 2.5 NA engine and always use factory subaru gaskets. For turbos the factory gaskets are good for the typical street car, with typical "stage 2" etc stuff.
Blown head gaskets, warped heads and a piston melted to the cylinder wall Borjaq Warranty Issues & SOA Problems 13 05-22-2010 11:16 PM
Help! FAST! Do I need to use gasket sealer, when replaceing my head gaskets?! wighti Tri-State Area Forum 5 10-05-2003 11:19 PM
Which head gaskets on EJ22T with EJ25 SOHC heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 05-11-2002 12:08 PM
Leaky Head Gasket & Water Pump Gasket - MY00 Forester lark6 Normally Aspirated Powertrain 20 11-10-2001 11:22 PM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 12:40 PM
