![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 176989
Vehicle:2004 STi & WRX PSM |
is it possible to fit 18x9's on an 04 wrx with out modifying the fenders?
#2 |
Member#: 35746
BAIC
Vehicle:06 White GDF Wrong Fitment Crew #001 |
depends on the wheels offset/tire size and suspension setup. but generally speaking, they wont fit with unmodified fenders.
#3 |
Member#: 176989
well right now i just have the stuck struts with eibach springs, but i will be getting bilstein coils relatively soon, as for the offset, well which ever one would fit, the wheel i like is 18x9 +30, idk if that will work, but im would rather just look at a diff. wheel than get all into fender modding
#4 |
Member#: 78952
Vehicle:2005 WRX CGM |
That would stick out pretty far dude unless you decide to run some massive camber. Even then you'll most likely stick out in the rear.
#5 |
Member#: 86659
Vehicle:2005 WRX Sedan WR Blue |
Thats is a pretty common size but it does require fender rolling.
#6 |
Member#: 151449
BAIC
Vehicle:2007 Nissan 350Z Carbon Silver |
Definitely Fender Rolling and you will need to run about 2* Neg. Camber in the rear. Also good thing you got coilovers since they are a lot stiffer, lot less travel than springs, so you can go lower without fearing hitting a bump and cutting a tire lol. MIGHT need slight fender pull in the rear deciding on tire size.
John |
#7 |
Member#: 176989
is there any offset that would avoid rolling or is it inevitable?
#8 |
Member#: 86659
maybe an offset in the 40's with some aggressive camber but then you will have to worry about inner clearance.
#9 | |
Member#: 4718
VIC
Vehicle:~ too many to list |
That's about as aggressive as you want to go with a streetable camber, and very rear minor fender mods that you could do at home. If your coilovers are stiff, you may be able to go +35. It all comes down to paying to play with wide and low. Coilovers, rear fender mods, and camber are your friend if you want to safely go 18x9", and still run daily. good luck. 18x9" looks so cool. ![]() |
#10 | |
Member#: 45323
South East
Vehicle:MY05 Impreza WRX STi Pastelito Racing & SFSOC |
i've seen a WRX rub with a 235/45/17 on a 17x8 +45mm and RCE Yellows. to run a 9" wheel on a WRX or 04 STi you need to modify the rear fenders or have very stiff suspension and a high ride height. (even if you were running a 225/40/18 tire). find a good fender roller local and roll the fenders, if done right you wont have any issues. |
#11 | |
Member#: 126003
International
Vehicle:2003 ... grey |
#12 | |
Member#: 45323
South East
the 05 STi has a smaller "lip" under the rear fender then the 05 WRX. the WRX can get more clearance easier then an 05 STi. WRX just needs a roll and it will have more clearance then a stock 05 STi. to get the same clearance on a 05 STi you have to do this... How To: Properly Modify 05+ GD STi Rear Fenders |
#13 |
Member#: 126003
International
that is good info wrx8. thx.
#14 | |
#Belieber
Moderator Member#: 140163
Vehicle:03 STi hellaflunctional |
18x8.5 +48 with 255/35/18s fit beautifully on my 04 sti with rce yellows after a mild fender roll i have about 5mm's to play with to the outer fender, but inner clearance is about 1-2mm max ![]() does this apply to 17x9 or 18x9 with something closer to a +40 offset? +35 would require rear camber bolts and a more aggressive fender roll. |
#15 |
Member#: 45323
South East
it applies to all 9" wheels.
i've seen a WRX rub with an 8" +45mm and a 235/45/17 tire on RCE yellows. i've also seen an 04 STi with a stiff enough suspension and high enough ride height to run 17x10s and 275s. the 9" +40mm would def require a fender roll in the rear of a wrx, the +35mm would be the same with more camber. |
| Thread Tools | |
| Display Modes | |
| My '04 STi now has 18x9's on it... | Cmoore711 | Member's Car Gallery | 52 | 12-19-2008 12:40 PM |
| Looking for some 18x9's with a 5x100 Bolt Pattern | wrx03.4wz | Tire & Wheel | 10 | 10-31-2008 03:43 PM |
| Wheel advice. 18x9's Nike says just do it? | Cmoore711 | Tire & Wheel | 2 | 05-30-2007 09:00 PM |
| 18x9's and 255's on a sti oh my... | jetfan8178 | Tire & Wheel | 59 | 10-03-2006 06:07 AM |
| 18x9's not enough? Oh, maybe some 18x9.5's. | jetfan8178 | Tire & Wheel | 14 | 09-12-2006 02:13 PM |
