Old 07-01-2008, 04:53 PM   #1
lemon19mmm
Member#: 144545
GG Wagon
Default My Hybrid Questions.. Thanks
EJ257 shortblock
100 mm JE Pistons/8.5:1 CR
Cosworth bearings
WRX HEAD/ STI CAMS
My goal is a fun and reliable auto-x,HPDE car.
1.Should I run thicker HG to keep CR low? If so, what's your suggestion?
2.Do I need to do some mods to make the combustion chambers match the 100mm bore on STI block?
3.How hard is it to swap the sti cams? I alreay block the holes on the sti intake cams. I did cams swap in sr20det and evo before.
I was running a normal fmic 18G setup and ra gears before I spun a bearing in my EJ205.
Thanks in advance..
lemon19mmm is offline   Reply With Quote
Old 07-01-2008, 07:11 PM   #2
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
have you built it yet? you can custom order your pistons to give you the CR you want with the stock HG thickness (most recommended).
lower CR is safer, especially if you're going to track it.
UP2MTNS is offline   Reply With Quote
Old 07-01-2008, 07:37 PM   #3
lemon19mmm
Member#: 144545
GG Wagon
The shorblock is done. Therefore, if I wanna make the CR lower, I think playing with HG would be my only option.
Thanks..
Old 07-02-2008, 02:40 PM   #4
lemon19mmm
Member#: 144545
GG Wagon
bump for more replies...
Old 07-02-2008, 03:34 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You could massage the CC on the heads and use very dished valves to lower compression a bit. Have you heads c.c'd and calculate it out.
Old 07-02-2008, 03:55 PM   #6
rainwrx
Member#: 68955
2005 WRX Hybrid
Needs Paint
Why is that?
rainwrx is offline   Reply With Quote
Old 07-02-2008, 04:47 PM   #7
rainwrx
Member#: 68955
2005 WRX Hybrid
Needs Paint
Lemon, I too have a higher compression hybrid. I've been advised by several engine builders and tuners to avoid using a HG to deal with compression. The correct way to do that is with pistons. I've also been advised that the higher compression is not really an issue -- just tune properly for it.
At the end of the day, what matters most are your goals for that engine and car. In my case, I wanted a strong daily driver that I could enjoy at several HPDE's a year. Not a dedicated track car or all-out HP monster by any means.
What are your goals?
Old 07-02-2008, 08:10 PM   #8
lemon19mmm
Member#: 144545
GG Wagon
kellygnsd-- sounds like a good idea...Thanks
rainwrx-- it's not my daily driver and it's not a crazy race car either. Like I said, my goal is a fun and reliable HPDE, auto-x car.
Thanks guys..
Old 07-03-2008, 10:01 PM   #9
lemon19mmm
Member#: 144545
GG Wagon
Any more suggestions?
Old 07-07-2008, 05:03 PM   #10
lemon19mmm
Member#: 144545
GG Wagon
bump.....
Old 07-07-2008, 05:36 PM   #11
kellygnsd
Member#: 32669
LINK G4 hybrid STi
These are your options. If you want to change you CR you can do it with pistons, a HG, or changing the volume of the heads. The head gasket is the least desirable method to do so.
Old 07-10-2008, 01:07 PM   #12
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I'm opening the chambers in my 2.0L heads to the 2.5L bore. This will have several benefits. It lowers the compression. It unshrouds the valves. It removes the sharp edge from the bore.
bluescoobywagon is offline   Reply With Quote
Old 08-28-2008, 04:24 PM   #13
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Any drawbacks to this approach? I've had this recommended to me, though the machine shop costs were going to be close to the price of aftermarket pistons.
Snowphun is offline   Reply With Quote
Old 08-28-2008, 04:27 PM   #14
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Price
Questions about my hybrid Dpsneeka Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-15-2009 04:29 PM
A couple quick questions on my hybrid RS-T build silentt Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-23-2007 11:34 PM
few questions on my hybrid build... NicFunkadelic Normally Aspirated with bolt-on Forced Induction Powertrain 25 02-16-2007 05:57 PM
wrx hybrid questions...my future set up...please help jimtweet Built Motor Discussion 2 09-06-2006 12:52 PM
question on my hybrid plans civic2scooby Subaru Conversions 5 08-17-2005 01:18 PM
