Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 07-01-2008, 05:23 PM   #1
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
Default Slim fan wiring
I am looking into getting a set of 2 slim fans to replace my stock ones since i will be upgrading my rad. some time soon, and the stock fans rub my IC pipes..
my question is, i see the factory fans have 4 wires, but the slim fans i have seen only have 2 wires, how do you wire them up to still work like the factory fans??
also i see aftermarket fans in 10in, 12in, and 14in, stock fans are 12in correct? any idea what cfm each stock fan moves?
Twiztidunreal is offline   Reply With Quote
Old 07-01-2008, 06:00 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
There should be two black wires that tie to ground on the original fan motors. The other two wires are for two speeds on the motor. You won't be able to have a second high speed if you use a motor with only two wires.
FS: New Mishimoto Aluminum Radiator, Two 12" Slim Fans, Cap, Fan Switch, 02~07WRX/STI wrx_limited Engine/Power/Exhaust 12 04-03-2009 08:44 AM
Hayden fan controller or stock wiring for slim fans Twiztidunreal Electrical & Lighting 5 12-19-2008 01:42 PM
Slim fan mounted on RAd xilles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-12-2007 11:30 PM
Best place for slim fans? John2.5RS South West Impreza Club Forum -- SWIC 2 10-17-2006 01:06 AM
Slim fans for radiator swap? yebokmj Subaru Conversions 2 03-03-2006 07:56 PM
