Old 07-01-2008, 06:23 PM   #1
avi1777
Member#: 147652
02 sti
white
Default major problem
hi guys
i have a build 2.5 sti with gt35r
i installed a fluidyne radiator and 72 deg thermostat
the problem is the car is loosing way to much water and there is no leak what so ever
for example-yesterdy during one and a half ours of tuning i lost 3 liters!!!
the water temp was alomost 120deg so i tought its a bad thermostat and in the morning i saw its fine but there was 3 liter of water less then full
no water in the oil and the fans work fine.
what can it be???
avi1777 is offline   Reply With Quote
Old 07-02-2008, 12:33 AM   #2
railguy
Member#: 53756
Could be 3 things, 1) you have a headgasket blown and your burning doenst seem like the case but possible. 2) you have a leak somewhere and you just dont know it. 3) when you installed the radiator and t-stat you did not properly bleed it and the coolant system worked out all the air pockets. Good thing about fluids is that they are real objects, they dont just dissappear.
railguy is offline   Reply With Quote
Old 07-02-2008, 07:46 AM   #3
avi1777
Member#: 147652
02 sti
white
thanks
Old 07-03-2008, 05:42 PM   #4
avi1777
Member#: 147652
02 sti
white
it was a bad head gasket
and the engine did only2000 miles on0.7 bar of boost
probably bad Assembly off the engine?
what do you think?they say the gasket got ****ed beacuse the car got hot but it was loosing water way beafore and i fill it up half a liter each time i saw water missing
i had a wrx once and it got hot for much longer than this sti and the head gasket was fine.
Old 07-03-2008, 07:15 PM   #5
charliew
Member#: 125304
Crappy head installation probably but also maybe not filled with coolant properly at begining.
charliew is offline   Reply With Quote
Old 07-03-2008, 07:36 PM   #6
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
when you pull off heads you need to send them to a machine shop that is very experience with subaru's to have them cleaned and check for straightness and lightly resurface the heads otherwise your almost always going to have headgasket problems.
if your using stock head bolts you need to replace them with new head bolts.
are engines use torq to yield bolts, that means these bolts stretch when used for the first time and should not be reused .
tekfoc is online now   Reply With Quote
Old 07-03-2008, 07:39 PM   #7
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Out of curiosity, what gaskets and head bolts/studs were used?
LiquidForce is offline   Reply With Quote
Old 07-04-2008, 07:29 AM   #8
avi1777
Member#: 147652
02 sti
white
I'm not sure about the gaskets but the bolts are ARP
the engine is made from cp,pauter and darton sleeves
i bought the good stuff but i think now it was bad Assembly
Old 07-04-2008, 11:01 AM   #9
tekfoc
Member#: 21392
2014 45 AMG MB
ARP head bolts need to be retorqed after some miles of use.
but alot of engine builders just torq the heads to a much higher speck instead of having the owner come back for a retorq of heads why! cost of labor for retorq most people are not going to go for that additional cost.
ARP wants you to retorq the heads .
Old 07-04-2008, 01:28 PM   #10
avi1777
Member#: 147652
02 sti
white
retorq means to tighten the bolts after some time/miles
Old 07-04-2008, 04:36 PM   #11
tekfoc
Member#: 21392
2014 45 AMG MB
YES, SO lets say it's 75 pounds of torq ,you would need to retorq them to 75 pounds.
Old 07-04-2008, 04:52 PM   #12
avi1777
Member#: 147652
02 sti
white
ok good to know
make sence
after how many miles usualy its recommended to retorq?
Old 07-04-2008, 10:12 PM   #13
tekfoc
Member#: 21392
2014 45 AMG MB
ok good to know
make sence
check with ARP for recommendation for when they should be retorqed .
I dont remember off hand .
Old 07-05-2008, 06:10 PM   #14
avi1777
Member#: 147652
02 sti
white
ok
it might be bad machined also-its converted from 2 to 2.5liter,i will know tomorow for sure
Old 07-05-2008, 06:41 PM   #15
LiquidForce
Member#: 12811
2002 2.5l Wrx
Did you assemble the motor yourself or have a shop do it?
The ARPs do need to be retorqued but you don't have to put miles on them first. That would be a serious pain on a Subaru motor since it would mean pulling the motor to get the cams out.
Do a search for the proper technique. If I remember correctly its torque to spec wait an hour and retorque to spec.
Old 07-06-2008, 11:27 AM   #16
avi1777
Member#: 147652
02 sti
white
i didnt assemble anything in the car,im a drummer
http://youtube.com/watch?v=YrlsARU9ty8
Major problems with turbo-back exhaust order from Renick Subaru WRXagon Vendor Reviews 2 04-12-2002 08:04 PM
OT: some major problems 98legacygt117 Legacy Forum 14 08-27-2001 05:12 PM
('93-'01) major problem/emergency with bushings install BSer Impreza Forum 9 07-04-2001 10:40 AM
major problems after alignment.. please help!! wistful Brakes, Steering & Suspension 4 06-25-2001 05:59 PM
Major problems in the General Forum subaruwrx General Forum Archive 1 12-06-2000 11:45 AM
