Old 07-01-2008, 09:48 PM   #1
thunder_lizard_1976
Member#: 145642
2007 WRX Ltd
Cuz Chicks Dig The Wagon
Question 07 WRX DRL delete = dim low beams?
The title pretty much says it all..Ever since I disabled the DRL's on my 07, the low beam main headlights don't seem quite as bright..They never really worked that well to begin with, but this is pathetic. Has anyone else noticed this, or am I possibly seeing things?
thunder_lizard_1976 is offline   Reply With Quote
Old 07-01-2008, 11:52 PM   #2
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Nope. Mine work fine.
I disabled the DRL's a few weeks after buying my car. I disconnected the ground...it's in a big plug that sits under the passenger corner of the dash. The thread is on here somewhere.
lennyTR is offline   Reply With Quote
Old 07-02-2008, 08:42 AM   #3
yakkosmurf
Member#: 81931
2008 STI (Stage 1)
WR Blue Mica w/ Gold BBS
Why are there so many threads about disabling DRLs? I'd prefer others to see me and avoid hitting me.
yakkosmurf is offline   Reply With Quote
Old 07-03-2008, 10:44 PM   #4
thunder_lizard_1976
Member#: 145642
2007 WRX Ltd
I mainly disabled them cause even on a low volt setting, the DRL's suck up some juice, and I personally like to be able to run just the parking lights in their place..I used the un-grounding method as well (red/ yellow center wire behind passenger dash) I wanted to know if others with the same mod had noticed an difference themselves....
Old 07-04-2008, 07:31 PM   #5
yakkosmurf
Member#: 81931
2008 STI (Stage 1)
...the DRL's suck up some juice...
You do realize your car has an alternator to generate electricity when it runs? The alternator spins the same speed with the same spinning friction no matter what loads its supporting. How does a 5% (at most) increase in draw make any bit of difference? What do you need the extra margin for?
Old 07-05-2008, 12:15 AM   #6
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
If you have an HID system (like me), you wouldn't want your HID's to be turned on with half power. That is the reason why I disabled mine. And besides that, for some reason I just have never like DRL's on any car...
They just don't agree with me.
Old 07-05-2008, 12:15 AM   #7
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
If you have an HID system (like me), you wouldn't want your HID's to be turned on with half power. That is the reason why I disabled mine. And besides that, for some reason I just have never liked DRL's on any car...
Old 07-05-2008, 02:57 AM   #8
matt.britt
Member#: 182184
2003 WRX sedan
This is not true. However, I agree that the load incurred by headlamps isn't really noticeable, though I doubt this is the reason someone would want to disable their DRLs.
matt.britt is offline   Reply With Quote
Old 07-05-2008, 08:19 AM   #9
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Ok, no flaming.
Even if the draw with the DRL's on is negligible, there's still a draw. A draw means more of a load imposed and to compensate, the idle must go up and with that, more fuel consumption.
To possibly solve your "dim" low beam problem, you may want to consider making/buying a head light wiring harness that is separate from the factory one.
In short, the low beam bulbs operate below their full potential due to the fact the power to feed the bulbs takes a long path through the harness and that the wires themselves are thin, say 18-gauge.
If you have a harness that's both shorter in length and a thicker gauge, you effectively reduce loss and resistance and thus more power gets to the bulbs so they are now working closer to their rated output.
Look at and first read this write-up by Daniel Stern Lighting: http://www.danielsternlighting.com/t...ys/relays.html
Look at Lightwerkz (if you want to purchase a harness -- scroll down to about the bottom of the page): http://lightwerkz.net/prod_subaru.htm
Look here at Nasioc (if you want to build your own harness) -- there are several write-ups. Also maybe ScoobyMods; IWSTI; etc.
I made my own low beam harness out of 12-gauge wire for both the power and ground circuits. The low beams are brighter and so are the high beams. Why, when I did not do anything to the high beams? This is because the low and high beams share the same power feed. Since the low beam now has its own power source, the high beams no longer share and thus have their own dedicated power source, thus more flows to the bulbs and thus, they are brighter.
Why not upgrade the high beam wires with their own dedicated harness? IMO, it's not worth it -- I don't drive around with the high beams on so why put the effort and resources where they're not needed.
Good luck and Happy Motoring!
Old 07-05-2008, 12:32 PM   #10
matt.britt
Member#: 182184
2003 WRX sedan
Quite right, but with alternator efficiency factored in (~55-60%), your low beams dissipate no more than about 0.13 horsepower per bulb. If you can notice a ~0.3 HP difference, hats off to you!
Old 07-05-2008, 02:31 PM   #11
Squishy
Member#: 128530
2013 BRZ
DRL's are not really that effective anyways.
http://www.motorists.org/drl/
They are a great gimmick though and I can't say that I miss them since I disabled them either.
Squishy is offline   Reply With Quote
Old 07-30-2008, 04:00 AM   #12
bonesmcgraw
Member#: 66710
05 sti
Did you remove the wire in the relay to the left of the blue relay behind the glove box. I believe it is yellow with a red stripe or is there a different wire to disconnect. The reason I ask is I just upgraded to a tsx hid retrofit and I disconnected that wire and my drls went off with my halogens. After my retrofit the hid's are now on and I can't figure out how to disable the drl's now.
bonesmcgraw is offline   Reply With Quote
Old 08-12-2008, 02:54 PM   #13
rexyrex
Member#: 169205
rexyrex is offline   Reply With Quote
need help w/ 07 WRX DRL disable and where 2 buy Badges.. GTIzzle07 Interior & Exterior Modification 6 10-08-2009 02:44 AM
02-07 WRX TGV deletes,P&P 02-05 WRX TB quazimoto Engine/Power/Exhaust 3 06-28-2009 10:41 AM
07 STi DRL delete justpunchit Newbies & FAQs 2 07-28-2008 11:59 PM
02-07 wrx DRL disconnect (easy) bhhamblin Interior & Exterior Modification 2 09-04-2007 11:59 AM
