Old 03-04-2002, 04:13 PM   #1
Tuning Factory Inc.
Vendor
Member#: 3600
Default Holy Expensive Bearing Batman!
Went down to pick up a release bearing for my WRX to install my Toda flywheel and Cusco clutch tomorrow. $150!!!! Yep you read that right. In all my years working on everything from Toyota to Nissan to Mazda to Honda I have NEVER seen a more insanely priced release bearing. Be forewarned people, when doing a clutch make sure to factor in the extra cost of the release bearing. The pilot bearing was within normal range of pricing as was the 2.5RS release bearing.
Tuning Factory Inc. is offline   Reply With Quote
Old 03-04-2002, 04:35 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
uh, what's it look like?
I can post up some pics of the cheap, mundane 2.5RS release bearing. I can even take some measurements if there's anyone curious if you have to use that expensive WRX bearing.
ColinL is offline   Reply With Quote
Old 03-04-2002, 06:41 PM   #3
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Post the part number too!
Conduit is offline   Reply With Quote
Old 03-04-2002, 09:48 PM   #4
mturmel
Member#: 2473
World Rally Blue
Yep, same here... about 250$ CDN... Damn those things are expensive, not even STi...
Matt
mturmel is offline   Reply With Quote
Old 03-04-2002, 10:21 PM   #5
preza
Member#: 1454
2000 2.5 RS-T
I guess if they would've slapped it in an STI box everything would fine
preza is offline   Reply With Quote
Old 03-05-2002, 03:49 AM   #6
Joel Gat, 1.8L
Member#: 32
Hello,
Err, uhh, Colin? That's unusual. You must be tired. Push type versus pull type? You really want to try to use the push in a pull clutch? Hee hee.
But yikes, those prices are scary.
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Old 03-05-2002, 10:55 AM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
right, I knew that.
Old 03-05-2002, 01:06 PM   #8
Z1 Performance
Member#: 9327
yepp...mega bucks. We jsut get ours from Japan with our orders.....about 1/2 the price
Z1 Performance is offline   Reply With Quote
Old 03-05-2002, 04:24 PM   #9
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I put a new clutch and pressure plate in when i swapped over and was amazed by the price of this bearing..
My transmission, Legacy Turbo, and the WRX are basically identical. Hydraulic, Pull type with expensive parts that are exclusive to US Subarus.
Eventually they'll get cheaper as they're more common, we can only hope.
DLC is offline   Reply With Quote
Old 03-05-2002, 07:32 PM   #10
mturmel
Member#: 2473
World Rally Blue
Z1,
now you're telling us!!
Matt
Old 03-06-2002, 12:13 AM   #11
Conduit
Member#: 6162
BTW, why are you replacing the bearing, is it bad? It may be that a 150 dollar bearing is pretty durable I wouldn't normally reuse the bearing either, but at that price, maybe it's something special that has a solid duty cycle.
Old 03-06-2002, 01:49 AM   #12
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
Ayeek.. so to replace my clutch and flywheel we are lookin at about $400 for the clutch $300 for the flywheel and $150 for the bearing and $200 - 300 to have someone install it? That has got to be the most expensive clutch install in history!
Evaider is offline   Reply With Quote
Old 03-06-2002, 01:56 PM   #13
Z1 Performance
Member#: 9327
not by a long shot.....try an All Trac Celica (book gives 24 hours...took us 20 hours..labor only!! Thankfully it was opn my car , as customer would have balked for sure!!
At teh point where you are dropping the dollars for a clutch ($500 to $1800 depending on setup), the $150 bearing pales in comparison. if you are doing the work yourself, no bother then. but if you ahev to pay a shop to install it, i doubt they would do teh job without the bearing...if they do, you will sign paper after paper not holding them lable when your bearing starts making noises, and then will charge you all over again..thuis time to just change the bearing.
it is definately worth changing if you are paying someone to do the labor
Old 03-06-2002, 06:44 PM   #14
NoLimitWRX
Member#: 6927
2016 WRX
Question
god, did you have to file the lead edge on the starter pinion gear when you installed the Toda flywheel??
after installing my JUN flywheel, the starter doesn't engage all the way. So the instructions say to 'bevel' the starter pinion gear, .... I'm just wondering exactly what they're talking about.
I'm guessing just filing down the edges of the teeth to make the lead edge 'thinner'.
anyway, just wondering if you, or anyone, has encountered this prob yet, and had some insight.
thanks
NoLimitWRX is offline   Reply With Quote
Old 03-06-2002, 11:20 PM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I agree - it is insane - my cost for the WRX bearing is almost 3x more costly than the same part for an RS!
I sell the RS bearing kits for $60 and have to charge $150 for the WRX and turbo legacy (with pilot and tool). Sux eh?
Larry
www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 03-09-2002, 02:26 AM   #16
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
So those things really are $150-$200.
Just the other day in another post I commented that I had never seen a tob so expensive in any cars from Japan. That guy was quoted $200.
Albert is offline   Reply With Quote
Old 03-09-2002, 10:04 AM   #17
Tuning Factory Inc.
Vendor
Member#: 3600
Ah yes the All trac, THE worst car ihn history to change a clutch on. I know, I used to own one.
Old 03-09-2002, 05:44 PM   #18
N/A
Member#: 133
TBA TBA
TBA
Man the Celica sounds like doing a clutch job on a GTI-R where the motor and transmission come out as one big piece out the bottom of the car. Instead of llike most cars the trans attaches to the engine on the GTI-R the engine has to be attached to the transmission cause its so large. A serious PITA.
You guys make me feel better about having spent $690 on a OS clutch for my car (not a Subaru). At least I got the clutch disc, pressure plate, lightweight chromoly flywheel and the throw out bearing as one set kit. No extra charges of anything. I only had to buy the pilot bearing and that was only about $5. $150 for a throw out bearing? That's BS! I'd be looking for a kit that included it if they were going to ask that much from the dealership.
N/A is offline   Reply With Quote
Holy Torque Steer Batman!! lenyx Brakes, Steering & Suspension 11 06-14-2002 07:22 PM
holy paint chips batman! Valien South East Region Forum 2 05-21-2002 03:36 AM
('93-'01) Holy Resale Value Batman!! CosmoTheCat Impreza Forum 5 04-20-2002 10:03 PM
holy fender gap batman b_tapper Member's Car Gallery 9 04-17-2002 11:41 AM
Holy flooded streets batman!! Legacy777 Texas Impreza Club Forum -- TXIC 15 04-08-2002 03:26 PM
