Old 07-02-2008, 02:10 AM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default Cruise control issues: 400 mile trip tomorrow!
1993 Legacy manual trans
150k miles
cruise control essentially stopped working all together about 2 years ago
Diaphram/spring/vac line is all good (checked it w/ my mouth)
put in pump/controller/relay out of a 90 legacy auto
cruise seems to stay on longer now... (by about 5 seconds) but the car bucks, surges, then the cruise turns off
what could be causing this?
ps no ABS
alex
Old 07-02-2008, 02:52 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
Have you checked for resistance in the wires? or possibly a bad ground?
also I would borrow or otherwise obtain a hand operated vacuum pump to test the vac lines and diaphram.
It's hard to say without diagrams or the car in front of me what would cause such strange behavior.
ProdriveDreams is offline   Reply With Quote
Old 07-02-2008, 03:19 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
the diaphram works fine
i dont know where the grounds are either...
Old 07-02-2008, 11:17 PM   #4
avk
Member#: 17252
'06 WX8
59E
This is sometimes caused by a faulty or out-of-adjustment clutch switch.
Not sure a controller from an auto model would work right: it may require grounding
one wire as I (vaguely) recall.
avk is offline   Reply With Quote
Cruise control not working, 6 hour trip tomorrow, please help badgerbugeye Electrical & Lighting 27 01-07-2010 06:20 PM
easiest way disconnecting cruise control cable from TB, cruise control removal 02-03 fastwrx25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2008 07:30 PM
UTEC: If the cruise light is flashing....cruise control doesn't work? bpwatts Engine Management & Tuning 4 07-10-2006 07:07 PM
Cruise Control Aint Cruising ahawks Service & Maintenance 0 10-21-2005 01:12 PM
Cruise actuator but no cruise control!! Improviser Normally Aspirated Powertrain 14 11-13-2002 04:48 PM
